The Shuttle XPC accessory PC63J is a high-end power supply with maximum output wattage of 500W suitable for XPCs with J-series case. With a low noise level of only 30dB, it is ideal for use in any noise-sensitive environments such as a library and offices. Thanks to its 80 PLUS Bronze certification for power-efficient devices, this power supply is also suitable for Energy Star compliant systems. Benefit from less power consumption and less energy costs using PC63J.
- Shuttle PC63J - power supply - 500 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- 80 PLUS Certification
- 80 PLUS Bronze
- 1.1 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +12V1 - 16 A , +12V2 - 16 A , +12V3 - 17 A , +3.3V - 18 A , +5V - 16 A , +5VSB - 2.5 A , -12V - 0.3 A
- Output connectors
- 1 x power 20 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 3 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- 8.2 cm x 20 cm x 5.3 cm
- Environmental Standards
- ENERGY STAR
- Designed For
- Shuttle SZ87R6; XPC SG41J1, SH55J2, SH67H3, SH67H7, SH87R6, SX58J3, SX79R5, SZ77R5
- ATX12V 2.3
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Overheat protection, over current protection, over voltage protection, overpower protection, overload protection, undervoltage protection, short-circuit protection
- FCC Class B certified, TUV, BSMI, cUL, CB, CCC
Sustainability Information
- ENERGY STAR
- 10 °C
- 50 °C
- Sound Emission
- 30 dB
- 8.2 cm
- 20 cm
- 5.3 cm
- 1.1 kg
- Designed For
- Shuttle SZ87R6 , Shuttle XPC SG41J1, SH55J2, SH67H3, SH67H7, SH87R6, SX58J3, SX79R5, SZ77R5
