Sennheiser SP 10 ML is a premium portable speakerphone designed for Unified Communications business professionals to make both personal and small group conferences on PC/softphone. Sennheiser HD sound quality and voice clarity provide better user interaction. Lightweight, streamlined styling and superb finish give a high-quality appearance. Features include dual talk function, echo canceling, music setting and a protective carrying pouch.
The design speaks for itself
With its streamlined styling and superb finish, the Sennheiser Speakerphone signals high-end quality wherever you choose to make your office. -
Exceptional sound for better communication
Replace PC and mobile phone speakers and microphone sound with legendary Sennheiser sound quality. Conference calls will never be the same. to operate with intuitive controasy use, clear microphone mute button, call and volume controls - plus practical and convenient cable management system. -
For the rhythm of the working day
Give yourself a break between calls and use your discrete speakerphone to hear music when you want to relax. protection. -
Iconic design
Streamlined styling, superb finish and a lightweight, compact design signal high-end quality wherever you choose to set up your office. -
Enjoy music
Sound-enhancement profile for music lets you take a break between calls to hear music when you want to relax. -
Exceptional sound
Replace PC and mobile phone speakers and microphone sound with legendary Sennheiser sound quality. Conference calls will never be the same. -
Outstanding communication
Sennheiser voice clarity, echo cancellation and dual talk function ensure a cleaner sound and a more natural conversation flow. -
Easy usage
Easy to use, clear microphone mute button, call and volume controls – plus practical and convenient cable management system.
- EPOS SP 10 ML - speakerphone
- Product Type
- Speakerphone - wired
- Recommended Use
- Computer
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Audio Specifications
- Frequency Response 150 - 15000 Hz
- Microphone
- Built-in
- Microphone Technology
- Electret condenser
- 2-year warranty
- Product Type
- 11 cm
- 11 cm
- 3 cm
- 190 g
- Recommended Use
- Computer
Audio Output
- Dynamic
- Wired
- 150 - 15000 Hz
- Magnet Material
- Neodymium
Microphone
- Directivity Angle
- 360°
- 150 - 6800 Hz
- Audio Input Details
- Omni-directional
- Connector Type
- USB 2.0 (4 PIN USB Type A)
- Included Accessories
- Carrying case
- Limited warranty - 2 years
