Wings on your mobile! Seagate M8 series employs advanced format technology (AFT) that raises the data storage density per unit area, enabling efficient and convenient data storage. It operates on a high-performance 3 gigabits per second SATA interface, provides an eight megabyte buffer memory and incorporates EcoSeek and NoiseGuard features for minimal noise levels. A redesign of the overall structure ensures enhanced shock resistance to protect the disc from physical fracture and data loss. Fast and reliable with a 5400rpm spin speed and 8MB buffer.
HIGH PERFORMANCE
Combining SATA 3Gbps with Native Command Queuing, generous high speed cache and large capacity, the Samsung Spinpoint M8 series hard drive delivers solid performance to meet the most demanding applications.
OPTIMIZED ACOUSTICS
Featuring advanced SilentSeek technology and NoiseGuard, the Samsung Spinpoint M8 series drive helps create an almost silent work space and keep your mind in peace.
- Spinpoint M8
- Max. 500GB formatted capacity per disk
- ATA Security Mode Feature Set
- SATA Native Command Queuing Feature
- ATA S.M.A.R.T. Feature Set
- TuMR/PMR head with FOD technology
- Serial ATA 3.0Gbps Interface Support
- Load/Unload Head Technology
- SilentSeek™
- NoiseGuard™
- Samsung SpinPoint M8 ST500LM012 - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology, S.M.A.R.T.
- 69.75 mm x 100.3 mm x 9.5 mm
- 107 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 500 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- 69.75 mm
- 100.3 mm
- 9.5 mm
- 107 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 145 MBps
- Seek Time
- 12 ms (average)
- Average Latency
- 5.6 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 3 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- 5 °C
- 55 °C
- 5 - 90% (non-condensing)
- Shock Tolerance
- 325 g @ 2ms half-sine pulse (operating) / 750 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 1.5 g @ RMS (random) (operating)
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.75 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.52 |
