Seagate Enterprise Capacity 3.5 HDD ST8000NM0075 Hard Drive 8TB
Quicklinx: CT9HWS00 Mfr#: ST8000NM0075
Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
  • Impressive capacity - designed for speed
  • World-class reliability meets high-capacity
    When building maximum density server and storage solutions with the 8TB Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs, while offering your users a consistent and predictable response rate.
  • Reliable, robust bulk data storage for a 24×7 world
    High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550TB per year, which is up to 10× the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs. Choose from 12Gb/s SAS or SATA 6Gb/s interfaces for easy integration into existing platforms.
  • Protect data with SED options
    Enterprise Capacity 3.5 HDD protects data where it lives - on the drive.
Seagate Exos 7E8 ST8000NM0075 - hard drive - 8 TB - SAS 12Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Dual Port, Humidity Sensor, Low Halogen, Super Parity, Power Balance technology, advanced format 512e, 24x7 availability
101.85 mm x 147 mm x 26.1 mm
780 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
8 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
780 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
237 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
9 Watt (idle) , 10 Watt (read)
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (non-operating)
4.9 g @ 10-500 Hz
