Life Happens. Back It Up.
Your Digital Life. Safe and Sound.
Backup Plus from Seagate is the simple, one-click way to protect and share your entire digital life–without getting in the way of the rest of your life.
• Mac OS and Time Machine® ready right out of the box
• Automatically save photos from your social networks
• Share photos and video to social networks with a click
• Install the downloadable HFS+ driver for PC, and use the drive interchangeably between Mac computers and PCs without reformatting
What is Backup Plus?
The Seagate Backup Plus for Mac desktop drive simplifies backup for consumers who want to protect their entire digital life locally or on social networks. The drive is formatted for Mac out of the box, making it compatible with Time Machine® software to provide the simplest and most efficient way to back up locally. Keep multiple copies of your files in case disaster strikes.
• Protect your precious memories with flexible backup that’s fully compatible with Time Machine® software
• Save the photos you've shared online—automatically
• Share photos and videos on social networks like Facebook and Flickr
• Upgrade your connection in a snap with swappable upgrade adapters
• Formatted for Mac but also works with Windows PCs
Huge 2TB capacity
Space for everything you've got. No more having to pick and choose what you protect.
Time Machine ready
It’s fully compatible with your Mac's Time Machine® software, so you just plug it in, set it up, and forget it.
Protect…
Photos, videos and more. Automatically.
Life is full of amazing moments you want to remember forever. The Backup Plus Desktop Drive for Mac provides easy plug-and-play Time Machine™ backups of all your stuff, so you know that even if "life happens" to your computer, your memories are always protected.
Save…
Your social life with a click.
With the Save feature, user-generated content can be backed up from your favorite social networks. Many people now use their smartphones to capture priceless moments. While these devices are handy and readily available, storage is not their strong suit. Capture a memory, post it on a social networking site and let the Seagate Dashboard automatically back up any content posted. Even if the file gets accidentally deleted from the device, another copy can be waiting.
Share…
Your favorite moments instantly.
The Share feature allows multiple files to be uploaded to social networks at once from your computer. The days of uploading individual files without creating a new album are gone! Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
System Requirement
• Mac OS X 10.6 or higher or Windows XP SP3 (32-bit and 64-bit) or higher operating systems
• FireWire® 800 or USB 2.0 port
• Install the downloadable HFS+ driver for PC, and use the drive interchangeably between Mac computers and PCs without reformatting.
- Seagate Backup Plus for Mac STCB2000902 - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Built-in capacity meter, automatic backup, Apple Time Machine compatible
- Power Source
- Included AC adapter
- Enclosure Colour
- White, black silver
- 124 mm x 44 mm x 158 mm
- 1.08 kg
- Capacity
- 2 TB
- Interface
- USB 3.0
- 124 mm
- 44 mm
- 158 mm
- 1.08 kg
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Software Included
- Seagate Dashboard
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8
- Included Accessories
- SuperSpeed USB adapter
- Cables Included
- 1 x USB 3.0 cable - 1.2 m
- Enclosure Colour
