The Seagate Slim portable drive is the thinnest external hard drive for consumers who want to back up their digital lives and take it on-the-go. At about the thickness of a pencil, the ultra-thin metal design allows you to slide the drive in your pocket, purse or backpack and carry it with you. Via the Seagate Dashboard, use the Protect function to set up a one-click plan or customize your scheduled local backup. Keep multiple copies of your files in case disaster strikes.
With the save feature, user-generated content can be backed up from your favorite social networks. Many people use their smartphones to capture priceless moments. Capture a memory, post it on a social networking site and let the Seagate dashboard automatically back up any content posted. Even if the file gets accidentally deleted from the device, another copy can be waiting.
The share feature allows multiple files to be uploaded to social networks at once from your computer. The days of uploading individual files without creating a new album are gone! Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
Mac OS X 10.6 or higher or Windows® 8, Windows 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)
Inside the Box
Seagate Slim for Mac drive
Quick start guide
Seagate Dashboard preloaded on drive
2-year limited warranty
18-inch (46cm) USB 3.0 cable
