Your basket is empty
Seagate 500GB Constellation ES 7200.1 7200RPM 32MB SATA300
Quicklinx: 75VHWS00 Mfr#: ST3500514NS
Constellation ES is the fourth generation 3.5-inch drive for enterprise 7200-rpm environments enabling cost-effective, highly efficient enterprise storage with highest capacities, best-in-class reliability, leading performance and optimized power and cooling. With its lowest power consumption and highest temperature tolerance, it optimizes chassis performance in tiered storage solutions. The only drive offering a choice of traditional 3Gbps enterprise SATA interface for seamless enterprise integration or the industry leading 6Gbps SAS enterprise interface for a more reliable, scalable and sustainable high performance enterprise solution.
Constellation ES drives offer high capacity at 2TB while providing enterprise robustness for Tier 2/nearline environments. They are differentiated from 3.5-inch desktop drives by offering enterprise-class reliability and superior data integrity with a UER of 1E10-15. Enterprise-class rotational vibration tolerance provides robust protection from chassis and fan vibrations. The drives are offered with either a 3Gbps SATA interface or a 6Gbps SAS 2.0 interface for superior data protection at industry-leading speeds.
Seagate Constellation ES ST3500514NS - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
Serial ATA-300
Data Transfer Rate
300 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
10.2 cm x 14.7 cm x 2.6 cm
0.59 kg
Microsoft Certification
Works with Windows Vista
5 years warranty
BlackArmor NAS 400, NAS 420, NAS 440
500 GB
3.5" x 1/3H
Serial ATA-300
Buffer Size
32 MB
Bytes per Sector
512
10.2 cm
14.7 cm
2.6 cm
0.59 kg
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
140 MBps
Seek Time
8.5 ms (average)
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x Serial ATA-300 - 7 pin Serial ATA
Compatible Bays
1 x internal - 3.5" x 1/3H
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Seagate BlackArmor NAS 400, NAS 420, NAS 440
