Centralises your backup and storage
The BlackArmor® NAS 220 storage server delivers easy-to-use centralised network storage and backup for pro-consumers and small businesses!
Highlights
- Supports up to 20 PCs and Macs
- Automatic, incremental and full-system backups for networked PCs
- Compatible with Time Machine software for Macs
- Secures your data with powerful hardware-based encryption
- FTP server functionality for remote file access
- Enables automatic data mirroring with RAID 1 configuration
- Time Machine® software compatible, for Mac® computer backup
- Streams media to DLNA®-compliant devices and computers running iTunes® software
- Includes two reliable, user-replaceable Seagate® hard drives
- Connect external drives, share a printer or use an uninterrupted power supply with the two USB 2.0 ports
- Secure files with powerful hardware-based encryption
- Microsoft® Active Directory 2003/2008 support for populating users and groups
- Multi-volume management
- Event email notification
- 3-year limited warranty
Perfect for when you need to
- Store and access files from a central, secure location
- Access and manage files remotely
- Stream media with DLNA or iTunes®
- Perform full-system backups automatically on network-connected PC and Mac® computers*
- Secure files with hardware-based encryption
- Share a USB printer with network-connected PCs and Macs
Ready to work
The BlackArmor NAS 220 storage server is shipped with two reliable, energy-efficient Seagate® hard drives preinstalled and configured in RAID 1 for automatic data mirroring. Easy-to-use software helps you choose the backup, performance and security options that are right for your business. And Seagate has you covered with available support that includes data recovery and priority tech support (data recovery services are sold separately).
Command from the field You can manage the BlackArmor NAS 220 storage server remotely with DDNS, which can be configured using an intuitive web-based management interface.
The BlackArmor NAS 220 storage server can also function as a secure FTP server, allowing remote access to files. Designate user access manually using the web-based management interface or integrate with Microsoft Active Directory.
Hardware for hard work
The BlackArmor® NAS 220 storage server comes with two user-replaceable, reliable Seagate® Barracuda® hard drives preinstalled. As your business grows, you can upgrade easily to larger capacity drives.
Additional BlackArmor NAS 220 storage server features include:
- A gigabit Ethernet port for local network connection, web-based management and remote access
- Two USB 2.0 ports for external drives, printers and UPS (uninterrupted power supply)
- An 800 MHZ processor; 128MB RAM
Business-grade protection
Software plays an important part in achieving business continuity, and the easy-to-use BlackArmor NAS 220 software package delivers layered protection for your business-critical data.
Rest easy with BlackArmor NAS 220 storage server features such as:
- Incremental and full-system automatic backup of network-connected PCs
- Bare-metal restore to recover your entire system, including the operating system, programs and settings in the event of PC hardware failure
- The ability to secure your files with powerful hardware-based encryption
- Additionally, BlackArmor NAS server software helps you configure the drives easily for the optimal mix of performance, redundancy and storage capacity.
- Height (mm) (maximum) 197.8
- Width (mm) (maximum) 104
- Length (mm) (maximum) 188
- One Ethernet port for local network connection, Web-based management and remote access
- Two USB 2.0 ports for external drives, printers and uninterrupted power supplies (UPS)
- Two internal SATA II ports
Performance that keeps pace with your business
The BlackArmor NAS 220 storage server makes no compromises when it comes to hardware, with Seagate Barracuda drives, 800 MHZ processor, 128 MB RAM and Gigabit Ethernet port, you will experience incredible performance - including read speeds of up to 40 MB/s in RAID 1 configuration. The BlackArmor NAS 220 storage server includes two energy efficient, reliable Seagate hard drives, which are user-replaceable, allowing you to upgrade to larger capacity drives as your business grows. -
Expansion
The two rear-mounted USB 2.0 ports allow you to connect external USB hard drives for additional storage, easily share a USB printer with your network connected computers or connect an uninterrupted power supply (UPS) to safeguard from power failure.
- Seagate BlackArmor NAS 220 - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.4 cm x 18.8 cm x 19.8 cm
- 3 kg ()
- Localisation
- Middle East, Africa, Europe
- Processor
- 800 MHz
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB SATA 3Gb/s
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- RAM
- 128 MB
- System Requirements
- Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 10.4 cm
- 18.8 cm
- 19.8 cm
- 3 kg ()
- Localisation
Processor / Memory
- Processors Installed
- 800 MHz
- RAM
- 128 MB
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD
- Capacity
- 2 x 2 TB
- Interface Type
- SATA 3Gb/s
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- FTP, Bonjour
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Apple Bonjour Protocol, Microsoft CIFS, Network File System (NFS), FTP, HTTP, HTTPS
- E-mail alert, iTunes server, FTP server
- DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A
- Cables Included
- 1 x network cable - 2 m
- Power Device
- External power adapter
- Software Included
- Seagate BlackArmor Discovery, Seagate BlackArmor Backup
- OS Required
- System Requirements Details
- Windows XP/Vista - Pentium III - 500 MHz - RAM 256 MB
- Limited warranty - 3 years
