Your basket is empty
Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive
Quicklinx: 7W95WS00 Mfr#: ST3000DM001
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£73.37 ex VAT
£88.04 inc VAT
The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by trusted performance, reliability and simplicity.
Seagate Desktop HDD ST3000DM001 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology
101.6 mm x 146.99 mm x 26.11 mm
626 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
512
101.6 mm
146.99 mm
26.11 mm
626 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps (read) / 156 MBps (write)
Spindle Speed
7200 rpm
Reliability
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
60 °C
Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5 Bundle deal on Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.43 | ordered upon request
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £3.50 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £9.99 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.40 | in stock
£94.38
saving £13.95
Cables
Including:
£76.07
saving £2.70
7W95 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £30.93
7W95 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £73.11
7W95 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £74.53
Type: Hard drive
Capacity: 3TB
Brand: Seagate
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
