The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by 30 years of trusted performance, reliability and simplicity.
Maximize hard drive storage densities
Seagate Desktop HDD, 1TB-per-disk technology incorporates 340,000 unique tracks in the width of a single inch. This incredible storage density drives new capacity possibilities and lowers your total storage costs. -
AcuTrac technology
Seagate AcuTrac technology enables storage densities with accurate reading and writing to nano-sized tracks that are only 75 nanometers wide! That's about 1/500th the size of the period at the end of this sentence.
- Seagate Desktop HDD ST2000DM001 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology
- 101.6 mm x 146.99 mm x 26.11 mm
- 626 g
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 512
- 101.6 mm
- 146.99 mm
- 26.11 mm
- 626 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps (read) / 156 MBps (write)
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
