Your basket is empty
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive
Quicklinx: 7XD5WS00 Mfr#: ST1000DM003
Form Factor: 3.5" x 1/4H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£37.49 ex VAT
£44.98 inc VAT
Express delivery Order within the next hour for delivery tomorrow
The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by 30 years of trusted performance, reliability and simplicity.
Seagate Desktop HDD ST1000DM003 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology
101.6 mm x 146.99 mm x 20.17 mm
400 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
1 TB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps (read) / 156 MBps (write)
Seek Time
9.5 ms (max)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/4H
Power Consumption
5.9 Watt (active) , 3.36 Watt (idle) , 0.63 Watt (stand by) , 0.63 Watt (sleep)
RoHS
60 °C
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5 Bundle deal on Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive
£53.81
saving £8.65
Cables
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £6.01 | in stock
£40.50
saving £3.01
7XD5 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £30.93
7XD5 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £73.11
7XD5 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £74.53
Type: Hard drive
Capacity: 1TB
Brand: Seagate
Price Range Ex VAT: 0 - 50
