Packed with the GPU technologies, the Radeon HD 6450 graphics processor is a visual upgrade that delivers eyefinity multi-display technology, HDMI for stereoscopic (3D) displays, DisplayPort as well as support for DirectX 11 for the most versatile solution for everyday computing.
40 nm process technology
Manufacturing process allows for efficient, high performance parts which use less power than their predecessors. -
PCI-Express
The PCI-Express specification doubles data throughput allowing you to exploit the full performance potential of your graphics card. -
AMD HD3D technology
Enjoy the most immersive experience possible with full support for high definition stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth. -
D-sub (VGA)
The 15-pin VGA connector is common to most monitors and high definition television. You can connect your LCD or CRT monitor/TV with D-sub VGA connector. -
Dual-link DVI
Equipped with the most popular dual link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60Hz. -
DisplayPort
Enjoy the benefits of the display interface, DisplayPort. With the ultra high HD resolution of 2560 x 1600 the graphics card ensures that you are able to support LCD monitors. -
Microsoft DirectX 11
Get intense gaming performance and unrivaled image quality with stunning 3D visual effects, realistic lighting and lifelike imagery with graphics cards supporting DirectX 11. Features in DirectX 11 bring lifelike gaming and an experience never possible on a PC before. -
Dolby TrueHD and DTSHD Master Audio support
Support for copy protected, high bandwidth, 7.1-channel surround sound over HDMI. Get a fully immersive, high definition audio experience with Blu-ray movies. -
AMD Parallel Processing technology
Accelerate the most demanding applications by offloading parallel data compute tasks from the CPU to GPU, dividing the tasks as evenly as possible for improved system performance and reliability.
