The SAPPHIRE HD 6450 FleX incorporates this SAPPHIRE exclusive feature into a mainstream graphics card and delivers the most cost-effective Eyefinity solution available for increased productivity in tasks such as editing or business applications. It can also be used in multi-screen information display systems where three low cost monitors can be directly connected to each FleX card installed. The SAPPHIRE HD 6450 FleX can support three DVI monitors in Eyefinity mode and deliver a true SLS (Single Large Surface) work area. The first two monitors are connected to the DVI outputs, as usual. A third DVI monitor can be connected to the HDMI output with the passive cable adapter supplied. Thus three DVI monitors can be used in Eyefinity mode without any additional investment.
Dual-Link DVI
Equipped with the most popular Dual Link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60Hz. -
HDMI 1.4a
HDMI 1.4a builds on previous generations of HDMI connectivity with support for Deep Color, 7.1 High Bitrate Audio, and 3D Stereoscopic support, ensuring the highest quality Blu-ray and video experience possible from your PC. -
Single-Link DVI-D
Supports Digital monitors up to 1920x1200 resolution. -
AMD Eyefinity
AMD Eyefinity technology maximizes your field of view across up to three displays, fully engaging your peripheral vision. For gamers this puts you right IN the game and for other applications it helps to increase productivity by maximizing your visual workspace so that you can see more windows simultaneously. AMD Eyefinity technology is also ideal for multimedia applications as it allows you to keep several 'palettes' or 'panels' open over larger workspace whist you edit your images or videos. -
3 DVI Eyefinity Out of the Box
Targeting maximum flexibility with minimum outlay, Sapphire FleX Technology simplifies AMD's multi-monitor Eyefinity solution by allowing 3 X DVI monitors to be connected to the board 'out of the box' WITHOUT the requirement for expensive DisplayPort monitors or Active Adapters. -
40nm Process Technology
Cutting edge manufacturing process allows for efficient, high performance parts which use less power than their predecessors. -
PCI-Express 2.0
The latest PCI-Express 2.0 specification doubles data throughput from 2.5Gbps to 5Gbps allowing you to exploit the full performance potential of your graphics card. -
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software. -
Microsoft DirectX 11
Get intense gaming performance and unrivaled image quality with stunning 3D visual effects, realistic lighting and lifelike imagery with SAPPHIRE graphics cards supporting DirectX 11. New features in DirectX 11 such as Hardware Tesselation, HDR Texture Compression, Multi-threading support and DirectCompute bring lifelike gaming and an experience never possible on a PC before. -
OpenGL 4.1
Supports the latest OpenGL API (Application Programming Interface) to accelerate performance of applications outside of DirectX, i.e. Adobe Autodesk 2D/3D graphic design. -
Shader Model 5.0
Supports the latest Shader Model 5.0 feature set including VTF (Vertex Texture Fetch) which is a key feature used extensively in many of the games that ship today. Without support for this feature the game will fall back to a lesser shader path resulting in the loss of cool, lifelike effects made possible by Shader Model 5.0 -
AMD Catalyst Control Center
The AMD Catalyst Control Center software application gives you complete control over the performance and visual quality of your SAPPHIRE AMD Radeon based graphics card allowing for the best experience on your PC. -
Dolby TrueHD and DTSHD Master Audio Support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies. (Requires a DVI to HDMI dongle on some models, an HD capable monitor and a Blu-ray drive) -
AMD PowerPlay
Dynamically manage power efficiency and take control of your performance with AMD's revolutionary AMD PowerPlay power management technology delivering high performance features when needed and conserving power when the demand on the graphics processor is low. This seemless technology dramatically reduces the overall power consumption allowing for break-through energy efficiency. -
Enhanced Unified Video Decoder 3 (UVD 3)
Watch the hottest Blu-ray movies or other HD content at full 1080p (and beyond!) display resolution. Enjoy a feature rich video experience with enhanced Unified Video Decoder 3 (UVD 3), offloading the bulk of the video decoding tasks from the CPU to the GPU allowing for a cooler, quieter and more balanced system.
- Sapphire RADEON HD 6450 FleX - graphics card - Radeon HD 6450 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- AMD Radeon HD 6450
- Memory
- 1 GB DDR3
- Core Clock
- 625 MHz
- Stream Processors
- 160
- Effective Memory Clock
- 1.6 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- DVI-I (dual link) , DVI-D (Single-Link) , HDMI , VGA - with adapter
- API Supported
- DirectX 11, DirectCompute, OpenGL 4.1
- Package Type
- Lite retail
- Microsoft Certification
- Compatible with Windows 7
- Bus Type
- Graphics Engine
- Core Clock
- 625 MHz
- Stream Processors
- 160
- Max Resolution
- 2560 x 1600 at 60 Hz
- API Supported
- Fanless heatsink, AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, FleX Technology, dual slot heatsink, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Bus Width
- 64-bit
- Min RAM Size
- 1 GB
- Required Power Supply
- 400 W
- Additional Requirements
- CD-ROM
- Included Accessories
- Low-profile bracket
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, AMD Catalyst Control Center
- Supported Windows 7 Features
- Windows Media Center
- Package Details
- Lite retail
