SAPPHIRE R7 260X with new AMD TrueAudio Technology, enable games feature more realistic environmental dynamics, sound effects, and directional audio. With new AMD Eyefinity Technology, R7 260X now supports up to 3 monitors without DisplayPort connected. With 2GB of the latest GDDR5 memory and 896 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions.
HDMI (with 3D)
Support for Deep Color, 7.1 High Bitrate Audio, and 3D Stereoscopic, ensuring the highest quality Blu-ray and video experience possible from your PC. -
DisplayPort 1.2
Doubling the effective bandwidth of previous DisplayPort implementations, DisplayPort 1.2 now includes support for Multi-Stream, allowing you to drive up to four separate monitors from a single DisplayPort 1.2 connector (requires DP1.2 monitors or Multi-Stream compatible hub), Stereoscopic 3D monitor support and adds support for high quality, lossless, 7.1 channel audio formats. -
Dual-Link DVI-D
Equipped with the most popular Dual Link DVI (Digital Visual Interface), this card is able to display ultra-high resolutions of up to 2560 x 1600 at 60Hz. -
Dual-Link DVI-I
Advanced GDDR5 Memory Technology
GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth. -
AMD Stream Technology
Accelerate the most demanding applications with AMD Stream technology and do more with your PC. AMD Stream Technology allows you to use the teraflops of compute power locked up in your graphics processer on tasks other than traditional graphics such as video encoding, at which the graphics processor is many, many times faster than using the CPU alone. -
AMD CrossFireX Multi-GPU Technology
Triple or Quadruple gaming power with AMD CrossFireX Multi-GPU Technology.AMD CrossFireX technology supports up to four graphics cards to be used in a single system. -
PCI-Express 2.0
The latest PCI-Express 2.0 specification doubles data throughput from 2.5Gbps to 5Gbps allowing you to exploit the full performance potential of your graphics card. -
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software. -
28 nm GCN (Graphic Core Next) Architecture
The new and 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in Processing Power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn't be a compromise. The AMD Radeon HD7900 Series with the new 28 nm GCN Architecture assures that it's not. -
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms. -
Discrete Digital Multi-Point Audio
The AMD Redeon HD 7900 Series is the first GPU that can simultaneously output multiple and discrete audio streams via HDMI and DisplayPort Output. -
DirectX 11.2
The tessellation performance on AMD Radeon R7/ R9 series is up to 2X faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good. -
OpenGL 4.3
OpenGL 4.3 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified. The memory management in handling shaders is more efficient as well. -
AMD Catalyst Control Center
The AMD Catalyst Control Center software application gives you complete control over the performance and visual quality of your SAPPHIRE AMD Radeon based graphics card allowing for the best experience on your PC. -
Dolby TrueHD and DTSHD Master Audio Support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies. (Requires a DVI to HDMI dongle on some models, an HD capable monitor and a Blu-ray drive) -
Anti-aliasing features
Supports advanced AA (Anti-aliasing) features to maximize your enjoyment of high definition gaming.
- Sapphire RADEON R7 260X OC - graphics card - Radeon R7 260X - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R7 260X
- Memory
- 1 GB GDDR5
- Core Clock
- 1050 MHz
- Stream Processors
- 896
- Effective Memory Clock
- 6 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 3
- DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
- API Supported
- OpenGL 4.3, DirectX 11.2, Mantle
- 3.5 cm x 17.7 cm x 10.6 cm
- Package Type
- Lite retail
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1050 MHz
- Stream Processors
- 896
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 3
- API Supported
- Dual Slot Fan Cooler, High dynamic-range (HDR) rendering, Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, AMD HD Media Accelerator, Multi-Sample Anti-Aliasing (MSAA), Digital Multi-Point Audio (DDMA), Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge Quad HD display support, 24x Custom Filter Anti-Aliasing (CFAA), AMD TrueAudio Technology
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6 GHz
- Bus Width
- 128-bit
- OS Required
- Microsoft DOS, Microsoft Windows 98, Microsoft Windows 98 Second Edition, Microsoft Windows 2000 Professional, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Min RAM Size
- 4 GB
- Required Power Supply
- 500 W
- Additional Requirements
- CD-ROM, adjacent PCI slot, 6 pin PCI Express power connector
- Included Accessories
- 6 pin to 4 pin power cable
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
- WHQL
- 3.5 cm
- 17.7 cm
- 10.6 cm
- Package Details
- Lite retail
