The Sapphire HD5450 graphic card offers the most features and functionality in their class with complete DirectX 11 support and the world's most advanced graphics, display features and technologies. The HD 5450 series is designed to give you stunning high definition entertainment from your PC, whether Blu-ray/HD DVD discs or other HD sources.
Accelerate
Perform tasks on a PC faster with ATI Stream technology, speed up demanding everyday applications and get more done in less time. -
Dominate
With DirectX 11 support you can play the latest HD games with unrivaled visual quality, astonishing realism and ultra-fast frame rates. -
Get unrivaled visual quality and intense gaming performance with support for Microsoft DirectX 11
Get striking 3D visual effects and dynamic interactivity with DirectX 11 support. DirectX 11 brings high levels of visual realism to gaming on the PC and you'll get top-notch performance for these titles with ATI Radeon HD 5400 series GPUs. -
Low power consumption, passive cooling, noise free
Sapphire HD5450 series consumes less 20W power. The passive cooling design is noise free.
- Sapphire RADEON HD 5450 - graphics card - Radeon HD 5450 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- ATI Radeon HD 5450
- Memory
- 1 GB DDR3
- Core Clock
- 650 MHz
- Stream Processors
- 80
- Effective Memory Clock
- 1.333 GHz
- Max Resolution
- 2560 x 1600
- DVI-I (dual link) , DVI-I (Single-Link) , VGA - with adapter
- API Supported
- DirectX 11, OpenGL 4.1
- Fanless
- Package Type
- Lite retail
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 650 MHz
- Stream Processors
- 80
- Process Technology
- 40 nm
- Max Resolution
- 2560 x 1600
- API Supported
- Avivo HD Technology, AMD CrossFireX Technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support, Shader Model 5.0
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.333 GHz
- OS Required
- Microsoft Windows Vista / XP / 7
- Min RAM Size
- 1 GB
- Required Power Supply
- 400 W
- Additional Requirements
- CD-ROM
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, AMD Catalyst Control Center
- Package Details
- Lite retail
