Continuing on the tradition of quad-output solutions, the ATI FirePro 2460 is ideal for financial and enterprise users who need the space- and power-saving advantages of a small form-factor PC but also want high-quality, high-resolution environments.
Low power consumption
ATI devotes products into the energy saving for the products to provide the customers with more energy-efficient products through product design, protecting the Earth together. -
Passive cooling package for silent operation
Offering 0 db environment for extreme quiet demand. No cooling fan eliminates fan failures, which helps increase reliability and is ideally suited for use in quite office environments. -
Full 30-bit precision display pipeline
With a full 30-bit display pipeline producing more than one billion colors (10-bit per RGB component). The ATI FirePro is ideally suited for applications that benefit from accurate color reproduction and superior visual quality. -
PCI Express 2.0 x16
The latest PCI-Express 2.0 specification doubles data throughput from 2.5 Gbps to 5 Gbps allowing you to exploit the full performance potential of your graphics card. -
ATI Eyefinity
ATI Eyefinity technology maximizes your field of view across up to 3 displays and above, fully engaging your peripheral vision. For professionals this puts you right in the software and for other applications it helps to increase productivity by maximizing your visual workspace so that you can see more windows simultaneously. ATI Eyefinity technology is also ideal for multimedia applications as it allows you to keep several 'palettes' or 'panels' open over a larger workspace whist you edit your images or videos.
- Sapphire ATI FirePro 2460 - graphics card - FirePRO 2460 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- ATI FirePRO 2460
- Memory
- 512 MB GDDR5
- Stream Processors
- 80
- Effective Memory Clock
- 2 GHz
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 1920 x 1200 / DisplayPort: 2560 x 1600
- 4 x Mini DisplayPort , 4 x DVI - with adapter
- API Supported
- DirectX 11, OpenGL 4.1
- Fanless
- 17 cm x 6.5 cm
- 3-year warranty
- Graphics card - low profile - fanless
- Bus Type
- Graphics Engine
- ATI FirePRO 2460
- Stream Processors
- 80
- Max Resolution
- 2560 x 1600
- API Supported
- ATI Eyefinity Technology
- Size
- 512 MB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 2 GHz
- Bandwidth
- 16 GBps
- Included Accessories
- Low-profile bracket
- Cables Included
- 4 x Mini DisplayPort-DVI cable
- WHQL, RoHS, WEEE, EMI
- 17 cm
- 6.5 cm
- Limited warranty - 3 years
