Introducing SATA 6 Gb/s high performance, reliable, and low power for an enhanced user experience
In sacrificing performance for capacity, traditional hard disk drives (HDDs) have not kept pace with evolving market needs. Customers do not want to choose between fast performance and portability, seamless experiences and long battery life, or capacity and reliability. They want it all.
With SanDisk X110 SSDs, OEMs can deliver what buyers want: blazing-fast performance in thin and light form factors with advanced power management. These multi-level cell (MLC) NAND flash drives are suited for both primary storage solutions and dual-drive caching designs. Utilizing 19 nm process technology, SanDisk X110 SSDs offer solid-state performance at a cost within reach of a wider market segment.
SanDisk® X110 SSDs, based on 19nm MLC NAND flash, bring all the benefits and speed of high performance SSDs to ultrabooks, notebooks and desktops at a competitive price.
The storage device can be used as either a standalone or as a caching solution in a dual drive configuration. In both situations, X110 SSDs provide superior performance over the standalone hard disk drive, meeting Intel® Ultrabook® performance requirements. The SanDisk X110 SSD is offered in a 2.5" and customized form factors, taking full advantage of the SATA 6 Gb/s high performance interface.
High performance. Enhanced user experience.
SanDisk X110 SSDs have high read/write performance to support daily computing uses that require enhanced multitasking capabilities. Uses like email, Web browsing, music, and virus scans. Without the ability to handle a high mixture of sequential and random read/write patterns, user experience can be significantly impacted.
The X110 SSDs address these issues by implementing a tiered caching technology -- a hierarchical three storage layer architecture that directs data pattern streams to one of the three most suitable layers: volatile cache (DDR DRAM), nCache™ (a non-volatile flash write cache), or mass storage (MLC NAND flash). The data pattern streams are then monitored and rearranged by a proprietary innovative multistreaming feature that reduces fragmentation and improves locality of data. This enables fast user response, no stuttering, better multitasking capabilities, and significantly improves the drive's long-term data endurance5, ensuring an enhanced user experience.
Low power consumption. Longer battery life.
The SanDisk X110 SSDs employ a low power architecture that significantly reduces the power consumed by devices in low power modes, allowing users to extend the charge cycles of the battery, which is highly desired by mobility applications.
Key Features & Spec
- Form Factors: Cased 2.5 inches (7mm)
- Interface: SATA Revision 3.0 (6 Gb/s) backward compatible to SATA Revision 2.0 (3 Gb/s) and SATA Revision 1.0 (1.5 Gb/s)
- Capacity (GB): 32, 64,128, 256**
- Sequential Read/Write: Up to 505MB/s / 445MB/s **
- 4K random Read/Write: Up to 81,000 / 44,000 IOPS
- MTBF Up to 2,000,000 hours**
- Endurance: 80 TBW
- Size (Cased 2.5"): 7.0mm x 69.85mm x 100.5mm
- Weight Cased 2.5": Up to 39.5 g
- DC Supply Cased 2.5": +5.0V, ±5%
- Standby Mode (Typical): 75mW (@ 3.3V)
- Active Power (Typical): 120mW (@ 3.3V)
- Operating Temperatures: 0°C to 70°C
- Storage Temperatures: -55°C to 85°C
- Acoustic Noise : 0dB
- Certifications: FCC, CE, UL, ULc, TUV, KC, BSMI, ACA, VCCI
Tiered caching technology offers improved responsiveness
From streaming video to multitasking, the needs of business and personal users are placing ever-increasing demands on today's hard drives. The SanDisk X110 SSD uses tiered caching technology to direct data streams to the appropriate layer for maximum performance, greatly improving responsiveness and extending the life of the flash drive. The X110 can reach sequential read/write speeds of up to 505/445MB/s and random read/write speeds of up to 81,000/44,000 IOPS. -
Built-In reliability combined with thermal throttling
A patrol read error prevention mechanism checks and corrects errors in the background with zero performance impact. Advanced NAND recovery techniques and powerful error detection and correction capabilities ensure reliable data reads under punishing conditions. The SanDisk X110 SSD uses write-minimization technology, which eliminates unnecessary write operations to increase endurance and performance, and supports thermal throttling to prevent overheating. -
Lower power consumption
The SanDisk X110 SSD employs a low power architecture that significantly reduces the power consumed by the device in reduced power modes, allowing users to extend the charge cycles of the battery; a feature that is highly desired by mobility applications. -
SanDisk, a trusted partner for OEMs worldwide
SanDisk is the world's largest dedicated provider of flash memory storage solutions, with a heritage of innovation that brings significant value to OEM computing solutions. Work with SanDisk's demonstrated technological leadership and integrated supply chain, and you'll have a partner in creating versatile designs for leading-edge products.
- SanDisk X110 - solid state drive - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- NAND Flash Memory Type
- 19nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), flash bad-block management, Background Garbage Collection, TRIM support, Dynamic and Static Wear Leveling, nCache Acceleration Technology
- 69.85 mm x 100.5 mm x 7 mm
- 39.5 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
- 39.5 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 505 MBps (read) / 445 MBps (write)
- 4KB Random Read
- 81000 IOPS
- 4KB Random Write
- 44000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 120 mW (active) , 75 mW (idle)
- UL, TUV, VCCI, BSMI, FCC, ULC, ACA, KC
- 0 °C
- 70 °C
- Sound Emission
- 0 dB
