Upgrade your laptop to high-performance and extend its battery life with the reliable SanDisk Ultra SSD. You'll enjoy faster boot-ups and shutdown in up to half the time compared to a 7200 rpm hard drive. The SanDisk Ultra SSD is backed by rigorous shock and vibration testing. The SanDisk SSD features no moving parts, quiet operation, and low power consumption as compared to a 7200 rpm hard drive.
Performance
- Sequential Read (up to): 530 MB/s
- Sequential Write (up to) 290 MB/s
- Random Read (up to): 80K IOPS
- Random Write (up to): 9K IOPS
- MTBF: 2.0M hrs
Game faster, work faster
With the SanDisk Ultra Plus SSD, you don't have to wait around to use your PC. The 128GB Solid State Drive boots up in seconds, so that you can start work or serious gaming more rapidly than before. You enjoy faster performance from boot-up to shut down as well, thanks to speeds of up to 530MB/s sequential read and up to 445MB/s sequential write . -
A simple way to step up to performance
SanDisk Ultra Plus SSDs are a simple DIY upgrade for PC/laptop users, delivering significantly faster working and gaming. -
Get more from your existing hardware
Now you don't need to commit a large amount of your budget to get higher levels of performance. The SanDisk Ultra Plus SSD enhances your existing hardware's performance without the need to invest in expensive replacements or spend money on short-term repairs. -
No moving parts
You can rely on SanDisk Ultra Plus SSDs. They have no moving parts to go wrong and are designed to be resistant to shocks up to up to 1500G @ 0.5 msec. With up to 2 million hours mean time before failure (MTBF) , you can depend on this solution being with you for the long-term. -
Save money and energy
By replacing your existing hard drive with the 128GB SanDisk Ultra Plus SSD, you can reduce your running costs. The drive consumes less power than a 7,200RPM hard drive so your laptop battery lasts longer. -
Make the most of what you already have
Technology is always changing, but no one wants to sacrifice their existing investment unnecessarily. The SanDisk Ultra Plus SSD is backward compatible with both SATA Revision 2.0 (3 Gb/s) and SATA Revision 1.0 (1.5 Gb/s), and, at just 0.28 by 3.95 by 2.75 inches (H x W x D), it will work with any PC or laptop with a 2.5 inch hard drive. You can be sure of continuing to get the most out of your existing hardware. -
Reassurance with performance
You can work or play with total peace of mind. The 128GB SanDisk Ultra Plus Solid State Drive is backed by a three-year warranty.
- SanDisk Ultra Plus - solid state drive - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- 69.85 mm x 100.5 mm x 7 mm
- 3-year warranty
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 530 MBps
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.12 Watt (active)
- Included Accessories
- 2.5mm mounting spacer
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance
- 1500 g @ 0.5ms
- Vibration Tolerance
- 5 g @ 10-2000 Hz (operating)
