SanDisk® SSD PLUS
Step up to SSD speeds
Performance
- More than 23x better performance than typical HDD
- Faster boot up, shut down, application load and response
Proven Reliability
- Shock resistant for proven durability--even if you drop your computer
- SSD Dashboard reports on disk status and available updates
- Flash memory protects your memories even if your computer fails
Comfort and Convenience
- Run cool and quiet in the office or at home
Step up to SSD speeds and inject new life into your laptop or desktop PC with a durable solid state drive from SanDisk. You'll experience quicker boot up and shut down, quicker application response and data transfer speeds than with a typical hard disk drive, at just a fraction of the cost of a new computer. You'll boost your cool factor, too, with a solid state drive that doesn't overheat, make noise or burn through battery. SanDisk® SSDs are tested and proven to be resistant to shock, vibration and temperature extremes, so your SSD keeps working, no matter where or how hard you use your computer.
Fast read speeds for less waiting, more doing
Sequential read speeds of up to 520MB/s mean faster boot up, faster application response, faster data transfer and better game playing than you've experienced from your laptop or desktop before.
SanDisk SSD Dashboard monitors drive status
Windows users can check their driver's status in real-time and be alerted to software updates. And it includes 3rd party software offers from Apricorn for cloning onto your new drive, Titanium+ Virus scanner from TrendMicro and Lojack recovery software from Absolute to secure your computer, too.
SSD resilience, longevity, and quiet
With no moving parts, your SanDisk SSD keeps your data safe even if you drop your notebook or tablet, while also running cooler and quieter than a typical notebook or tablet. It's resistant to vibration and temperature fluctuations. Plus, long battery life means a longer leash and higher productivity for your notebook or tablet, on the go.
Performance
Sequential Read (up to) 520 MB/s
Sequential Write (up to) 180 MB/s
- Dimensions: 2.75 x 3.96 x 0.28 in. (69.85mm x 100.5mm x 7.0 mm)
- Shock: Resistant up to 1500G
- Vibration: Resistant 5 gRMS, 10-2000 HZ / 4.9 gRMS, 7-800 HZ)
- Temperature: 32ºF to 158ºF (0ºC to 70 ºC)
- Interface: SATA Revision 3.0 (6 Gb/s)
- Endurance: MTBF: 1.75 million hours
Sequential read speeds of up to 520MB/s mean faster boot up, faster application response, faster data transfer and better game playing than you've experienced from your laptop or desktop before. -
- SanDisk SSD PLUS - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- 69.85 mm x 100.5 mm x 7 mm
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.84 |
