Samsung Xpress 28PPM Mono Laser Printer
Quicklinx: 9XM6WS00 Mfr#: SL-M2835DW/SEE
Improve productivity and efficiency with an easy-to-use printer that delivers the best bang for your buck.
You can easily print directly from your mobile device to the printer over your wireless network. Unlock your full potential with a mobile solution that allows you to print images, PDFs, and the full suite of Microsoft Office documents, including Word, PowerPoint, and Excel. You can work smarter and faster by harnessing the power of advanced Samsung connectivity.
Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2835DW Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher performance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
  • Professional performance
  • Makes your smartphone even smarter
    Print wirelessly and share effortlessly with the Samsung Xpress M2835DW. All it takes is a simple tap with its advanced NFC technology and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features.
  • Get print on tap!
    Simply tap your NFC-enabled mobile device to the Samsung Xpress M2835DW to quickly and easily establish a Wi-Fi direct connection, so you can print virtually any content from your smartphone or tablet.
  • Print wirelessly with mobile print app
    Release the full productivity of your mobile devices with the Samsung Mobile Print App, available for iPhone, iPad, Android, and Windows Phone devices. You can easily print directly from your mobile device to the printer over your wireless network. Unlock your full potential with a mobile solution that allows you to print images, PDFs, and the full suite of Microsoft Office documents, including Word, PowerPoint, and Excel. You can work smarter and faster by harnessing the power of advanced Samsung connectivity.
  • Print anywhere with Google Cloud print
    Google Cloud Print works on Smartphone, Tablet PC, Google Chromebooks, PC/Notebooks and Other Web connected devices. Once enabled, you can print from anywhere in world with an internet connection.
  • No need to call for service
    Confusing error messages are a thing of the past. Just tap your NFC-enabled smartphone to the printer and you'll be guided through a step by step series of troubleshooting images or videos so you can get to work faster.
  • Print fast, don't wait
    However demanding your professional printing needs, the Samsung Xpress M2835DW delivers great results - fast. Save time by printing complex documents at speeds of up to 29 pages per minute (PPM) thanks to a powerful 600MHz processor and 128MB of memory.
  • Give a good impression
  • Print with more paper types
    Whatever you need to print, your Samsung Xpress M2835DW Series can handle it. The small but robust printer can use a range of media including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. You can easily select the paper type you need from the multipurpose (MP) tray, so it's convenient as well as flexible.
  • Easy ECO driver
    Save up to 20 percent on printer toner with Samsung's Easy Eco Driver. This useful software also reduces paper and energy consumption by giving users the option to remove unnecessary text and images, converting them from bitmap to sketches.
Samsung Xpress M2835DW - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
7.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 28 ppm - B/W - A4 (210 x 297 mm) , Up to 29 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
4800 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
600 MHz
RAM Installed (Max)
128 MB
Language Simulation
PCL 5E, PCL 6, SPL (Samsung Printer Language)
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, card stock
Total Media Capacity
250 sheets
Media Handling
250-sheet paper cassette, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
12000 pages
Print server
Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.9
36.8 cm x 33.45 cm x 20.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
4800 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Language Simulation
Media Handling
600 MHz
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
12000 pages
Print server
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages
Power supply - internal
400 Watt
Power Consumption Stand by
45 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
26 dBA
Sound Emission (Operating)
50 dBA
36.8 cm
33.45 cm
20.2 cm
7.4 kg
