The Samsung Shape M7 supports dual-band Wi-Fi, which ensures an uninterrupted stream across virtually any device. Additionally, Multi-Channel Mesh Network technology prevents network traffic problems by automatically searching for and finding clear audio data paths. Compatible with a variety of apps including Amazon Cloud Player, Pandora, Rhapsody, TuneIn Radio and more, the system can be customized to play different music in different rooms, or the same music throughout the home. Customers can also access content from their own library of music whether it is stored on a smartphone, a laptop or a PC.
The Samsung Shape M7 offers visual harmony within any room environment. Its unique design affords a wide variety of placement choices allowing it to fit snugly in the corner of the wall as if it were custom-designed for the space. It can also be positioned vertically or horizontally for maximum versatility. Wherever the user decides to put the unit - on a table, on a shelf or hanging on the wall with the optional wall mount kit, the system's minimalist design and wire-free aesthetics will feel right at home in any décor.
Shape your music
SHAPE Wireless Audio System lets you integrate music around how you live. Whether it's a single speaker in one room, or a multi room system in two rooms or every room in your home, it's never been easier to immerse yourself in your favorite sounds. -
The future of wireless speakers
With its adaptive design, exceptional audio performance, and simple wireless connectivity, the speaker reinvents how you listen. Getting started is easy - plug in the speaker, connect your device via Bluetooth or Wi-Fi with the free app, and start listening. -
Designed for flexibility
The unique triangular design fits your home; on a shelf, in a cabinet, or tucked into the corner. Use one speaker horizontally for stereo audio or a pair vertically for true left/right separation. -
Premium sound quality
The innovative 5 component speakers deliver premium sound quality. The woofer produces deeper, tighter bass, the advanced mid-range drivers create richer natural tones, and premium tweeters are crisp and clear to bring your music to life. -
Connect with Bluetooth & NFC
Send your music directly from your Bluetooth enabled smartphone, tablet, computer or Samsung TV to a SHAPE speaker. You can even simply tap to connect with your NFC enabled devices to establish an instant wireless connection. -
Play TV sound wirelessly
Enhance your TV's sound quality without the hassle of wires. Simply connect your TV Sound Connect enabled Samsung TV to a SHAPE Wireless Speaker to instantly take your TV's audio to the next level. -
Take control of your music
The app, available for Android and iOS, let's you truly control your music. Start the app, set up your speakers, and integrate your music sources and songs to play. The app can even allow you to control multiple speakers throughout your house at the same time. -
All of your music in one place
The easy to use app lets you access and play your music all in one place. Listen to your music library, the millions of songs from internet radio or the music streaming services you subscribe to. -
Connect via dual band Wi-Fi
The app uses Dual Band Wi-Fi to stream your music, whether to a single speaker, or to multiple speakers throughout your home. Dual Band Wi-Fi provides a stronger signal to ensure the best possible sound experience. -
Integrate your music services
The app seamlessly integrates with top streaming music services, so you can play music from multiple sources at the same time. You can customize your music library from Pandora, Rhapsody, iTunes, TuneIn, Amazon Cloud Player and much more. Just select your service via the app and you're good to go. -
Drag & Drop to play
Using the app, it's easy to select and listen to music from your entire library. Simply drag and drop the music to the selected speaker for easy enjoyment. -
Sound throughout the home
When you add more speakers and a Hub, the SHAPE multi room system really comes to life. It's a plug & play system, where you can add speakers throughout your home, and take complete control of your music. -
The Hub
The Hub, a small standalone box, works with the app to allow you to connect multiple speakers into a multi room system. By simply plugging the hub into your router and connecting via the app, you can connect, group & control your speakers to customize your music to fit your life. -
One system, many options
Using the Hub, app, and multiple speakers, you have incredible flexibility in how you choose to play your music. Play one song in one room, different songs from different sources in each room, one song across all speakers, or any combination that fits your mood. All simply controlled through the app. -
Quick, easy set-up
Unlike yesterday's complex systems that require wiring your house, complex integration, or multiple network connections, it's quick and easy to set up a true multi-room audio system with SHAPE .
- Samsung SHAPE M7 - speaker - wireless
- Product Type
- Speaker
- Internet radio
- Speaker Type
- Active
- Amplifier
- Integrated
- Fast Ethernet, Bluetooth, Wi-Fi, NFC
- DLNA
- Audio Formats
- WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless, OGG
- White
- Built-in Decoders
- Dolby Digital, DTS decoder
- 40.2 cm x 13.7 cm x 19.4 cm
- 3.8 kg
- Product Type
- Speaker
- Internet radio
- Enclosure Colour
- White
Speaker System
- Speaker Type
- Active
- Signal-To-Noise Ratio
- 65 dB
- Amplifier
- Integrated
- IEEE 802.3u (Fast Ethernet), Bluetooth, Wi-Fi, Near Field Communication (NFC)
- DLNA
- Recommended Placing
- Wall-mountable, table-top
- Built-in Decoders
- Audio Formats
- Additional Features
- Samsung AllShare technology, software update via USB, smartphone remote controlled, TV SoundConnect technology
Speaker System Details
- Driver Details
- Speaker: woofer driver - 4" , Speaker: 2 x tweeter driver - 0.75" , Speaker: 2 x mid-range driver - 2.2"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , LAN (RJ-45)
- Included Accessories
- Power adapter, stand
- Power Source
- AC power adapter
- 24 Watt
- 40.2 cm
- 13.7 cm
- 19.4 cm
- 3.8 kg
