With thoughtful design and engineering, the SE591C is much more than a monitor with a stunning look. Featuring a glossy body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it’s carefully designed to keep the focus on your content viewing pleasure. Its optimal curvature ensures comfortable viewing, delivering a wider field of view that is pleasant for your eyes.
Curved around your eyes for the ultimate viewing comfort
The optimal curvature ensures comfortable viewing, delivering a wider field of view that is pleasant for the eyes. -
Brilliant picture quality from every angle
Advanced static contrast ratio provides a truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors and less light leakage. Wide viewing angle delivers a 178-degree wide viewing angle horizontally and vertically for optimal viewing experience from any angle. -
Sophisticated design in a glossy T-shaped stand with a metallic touch
With thoughtful design and engineering, the SE591C is much more than a monitor with stunning looks. Featuring a glossy body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it’s carefully designed to keep the focus on your content viewing pleasure. -
Take your entertainment to heights of immersion and comfort
The SE591C was created with powerful dual stereo speakers built right into the curve. The speakers deliver rich and original sound. Game mode instantly adjusts your monitor settings for an optimized gaming experience through the on-screen display. -
High refresh rate
See every fast on-screen motion clearly and smoothly without any motion blur, judder or ghosting. -
Easy on the eyes for a more comfortable viewing experience
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
- Samsung S27E591C - SE591C Series - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Speakers
- Internal
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy white
- 62.32 cm x 18.16 cm x 46.3 cm
- 5.65 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, ISO9241-307
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 27"
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, power off timer, HDCP, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Image Size
- Glossy white
- 62.32 cm x 18.16 cm x 46.3 cm - with stand
- 5.65 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 5 Watt
- VGA , HDMI , DisplayPort , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x audio cable
- Power Supply
- External
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 62.32 cm - depth: 18.16 cm - height: 46.3 cm - weight: 5.65 kg , Without stand - width: 62.32 cm - depth: 5.99 cm - height: 36.57 cm - weight: 5.03 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
