Samsung S27D590C 27" 1920x1080 4ms VGA HDMI DisplayPort LED Curved Monitor
CURVED SCREEN & FLICKER FREE TECHNOLOGY GIVE MORE COMFORTABLE VIEWING
Quicklinx: B2H4WS00 Mfr#: LS27D590CS/EN
The SD590C boasts a curved screen that takes your entertainment experience to a whole new level. The radius and depth of the curve create a wider field of view and make the screen seem larger and more immersive than a flat screen of the same size. And because the screen edges are physically closer, matching the natural curves of your eyes, you get uniform viewing distance across the entire screen a more comfortable viewing experience that is easy on your eyes.
  • Elegant minimal design created by a smooth ergonomic curve and refined metallic stand
    To design the curve on the SD590C monitor, Samsung carefully studied how the human eye works to find just the right curve radius for the screen so that every part is at the same distance to your eye and the viewing is more comfortable and immersive. The monitor also features a clean and understated look that keeps you focused on your content. Elevated by a curved stand and angled neck and framed perfectly by a narrow bezel, the picture almost seems to float weightlessly, its elegant silhouette enhanced by the monitor's clean back.
  • Mega Dynamic Contrast and brilliant viewing experiences from every angle
    The SD590C provides enhanced viewing from any angle, thanks to its curved screen and 178-degree extra-wide viewing angle. It also features clear viewing vertically and horizontally, and a 3000:1 Mega Dynamic Contrast Ratio that complements the curved screen, providing truly lifelike pictures with deeper blacks, pristine whites, and amazingly bright colors. With the screen's wide field of view, you can enjoy all your multimedia content freely from nearly anywhere in the room and with incredible picture quality.
  • Entertainment content comes alive with stereo speakers built right into the curved screen
    Truly immersive viewing from a curved screen deserves equally immersive surround sound. That is why the SD590C was created with 5-Watt, 2-channel dual stereo speakers built right into the curve, delivering rich, high-quality stereo sound that envelops you and enhances your movies and music in a way that you'll think you're at a movie theater or concert. Enjoy the total solution for vision and sound that takes your entertainment to new heights, all in the comfort of your home.
  • Realistic gaming enhanced by a curved screen lets you step right into the game
    With just one touch of a button, Game Mode instantly adjusts your monitor settings for an optimized gaming experience. It intelligently detects changes in scenes, enhances the color, and alters the screen's contrast to make the darks darker and light spots lighter, so you can see all the action at all times. And with the amazing curved screen, all that action is more immersive than ever, plunging you into a gaming experience so exhilarating it will keep you right at the edge of your seat.
  • Give comfort to your eyes with Flicker Free
    Flicker Free technology protects your eyes from the constant strain caused by flickering screens on conventional monitors so you can work and enjoy reading, playing games, watching movies, and editing photos for longer without eye fatigue. Have a more pleasing immersive visual experience with Flicker Free.
  • Go for a higher level of immersion with multiple curved screens
    With the curved SD590C, you can expand your world of immersive entertainment by connecting two or even three monitors simultaneously to create a wider, gentler curve that delivers an incredibly immersive viewing experience for all your games and multimedia content.
  • Connectivity that comes optimized for entertainment
    The Samsung SD590C comes with a high-quality HDMI cable and all the connections you need to make the most of your entertainment. Connect to game consoles, Blu-ray players and other AV devices with the convenience and quality of HDMI, or use the D-Sub ports to connect to PCs. It even has a Display Port, making it simple and easy to connect to other displays.
Samsung S27D590CS - SD590C Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Glossy black
62.35 cm x 18.2 cm x 46.3 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B
Display Type
Energy Class
Class B
50 kWh
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Safe, Mercury free, Image Size
Glossy black
62.35 cm x 18.2 cm x 46.3 cm - with stand
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-2/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable
DDC-2B
Power Supply
External
Input Voltage
34 W
Power Consumption (Typical)
35 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.35 cm - depth: 18.2 cm - height: 46.3 cm - weight: 5.6 kg , Without stand - width: 62.35 cm - depth: 5.95 cm - height: 36.6 cm - weight: 5 kg
Sustainability Information
ENERGY STAR Certified
