Samsung S24D300HS 24" 1920x1080 2ms VGA HDMI Black Monitor
Quicklinx: 9S5DWS00 Mfr#: LS24D300HS/XU
Experience amazing levels of color, brilliance and picture quality through the very latest in mega dynamic contrast ratio! Samsung SA300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the SA300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves.
  • Control brightness, conserve energy
    Eco saving makes saving energy easy! It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes, you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
  • See it your way with wider viewing angles
    How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes center stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favorite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Samsung S24D300H - SD300 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
High glossy black
56.9 cm x 19.7 cm x 41.72 cm
3.15 kg
Environmental Standards
ENERGY STAR Qualified
RoHS
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
High glossy black
56.9 cm x 19.7 cm x 41.72 cm - with stand
3.15 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
1 x VGA cable
RoHS
Power Supply
External
Input Voltage
23 W
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.15 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 2.8 kg
Sustainability Information
ENERGY STAR Certified
9S5D C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
