AD-PLS panels for an incredible experience
Samsung AD-PLS panels deliver 178° viewing angles for a wide point of view at a cost-competitive price point. Enjoy outstanding image quality with a sharp, clear picture even when viewed from off angles for greater convenience and versatility. -
More connectivity options
VGA, HDMI and DisplayPort give users flexibility in high-speed connectivity, offering connection capability with a wide range of devices. So whatever device you need to connect to today or in the future, the SC650 series keeps your options open. -
Built-in speakers
Integrated 2-way speakers provide outstanding stereo sound for an enhanced multimedia experience whether watching movies, listening to music or catching online news segments. Enjoy quality audio and a crisp, clear sound for your listening pleasure. -
LED technology saves energy
Samsung's LED technology and user-adjustable brightness settings enable enterprises to better manage power usage and reduce energy consumption by up to 50% as compared to traditional CCFL. Control costs and leave a light environmental footprint.
- Samsung S24C650BW - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Panel Type
- AD-PLS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 55.48 cm x 22.4 cm x 38.2 cm
- 5.7 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 24"
- Panel Type
- AD-PLS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicRotation, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 55.48 cm x 22.4 cm x 38.2 cm - with stand
- 5.7 kg
- VGA , DVI
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- -1/+95
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.1 Watt
- Included Software
- Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 55.48 cm - depth: 22.4 cm - height: 38.2 cm - weight: 5.7 kg , Without stand - width: 55.48 cm - depth: 5.42 cm - height: 35.935 cm - weight: 4.1 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
