Maximized your viewing and your workspace. The Samsung Series 2 LED Business Monitor features a stylish narrow bezel to make the most of the screen and reduce distraction. Thanks to its compact space-saving design, you can also use your workspace better and keep it tidy. To help you reduce business costs, it's more energy-efficient too, consuming just 0.1 watts of electricity when in standby mode. You can even use the VESA Wall Mount to hang it securely and make the most of your space.
- Samsung S24C200BL - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 55.46 cm x 18.5 cm x 41.23 cm
- 4.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Diagonal Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 55.46 cm x 18.5 cm x 41.23 cm - with stand
- 4.1 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 100 x 100 mm
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Included Software
- Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 55.46 cm - depth: 18.5 cm - height: 41.23 cm - weight: 4.1 kg , Without stand - width: 55.46 cm - depth: 7.7 cm - height: 33.05 cm - weight: 3.75 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80%
