- Samsung S22C150N - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24825 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- High glossy black
- 51.2 cm x 19.7 cm x 38.5 cm
- 3.1 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 81 kHz
- Video Bandwidth
- 148 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- High glossy black
- 51.2 cm x 19.7 cm x 38.5 cm - with stand
- 3.1 kg
- VGA
Mechanical
- Tilt
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 51.2 cm - depth: 19.7 cm - height: 38.5 cm - weight: 3.1 kg , Without stand - width: 51.2 cm - depth: 5.3 cm - height: 31.1 cm - weight: 2.7 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
