With a host of features to enhance the user experience, such as the Height Adjustable Stand (HAS), this monitor offers a truly personalized experience. The advanced LED monitors also minimized running costs, which is also good for the environment. So, if you are serious about working, then this is the perfect choice.
Maximize your monitor experience with the help of a chic narrow bezel. With its narrow bezel width, users benefit from reduced distraction when looking at the monitor and therefore can enjoy greater levels of concentration. The extra screen space also makes it easier to set up a dual monitor workstation, which also adds to work productivity. But for those who just want a smart looking monitor, the narrow bezel adds a sophisticated look and feel to any desk.
If you need a work monitor that uses office space efficiently, then Samsung LED Business monitor SC450 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SC450 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED Business monitor SC450.
Improve your work with HAS design
Find the perfect viewing experience with the help of Samsung's Height Adjustable Stand (HAS). Its simple controls allow for users to tailor their monitor height and angle to meet their exact eye level and therefore improve their productivity when working. It ensures that users are always benefitting from the best. -
Help business with cost-cutting technology
Minimize your work costs with the help of the DPMS 0.1W feature. It ensures that your Samsung Business monitor only consumes a maximum of 0.1 Watts while in standby mode. This amazingly low consumption is beneficial both financially and environmentally, and is simply unmatched by competitors. -
Keep your work space as efficient as your monitor
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SC450 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SC450 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SC450. -
Maximize your space with easy wall mounting
Give your monitor the best possible positioning with the VESA Wall Mount. Easy to mount and install, it is convenient, safe, compatible, and the perfect partner to your monitor. You will always have a great viewing angle and it also makes the most of your space with its slim design. -
Experience minimal design and maximum effect
Maximize your monitor experience with the help of a chic narrow bezel. With its narrow bezel width, users benefit from reduced distraction when looking at the monitor and therefore can enjoy greater levels of concentration. The extra screen space also makes it easier to set up a dual monitor workstation, which also adds to work productivity. But for those who just want a smart looking monitor, the narrow bezel adds a sophisticated look and feel to any desk. -
Upgrade to the next level with Mega Dynamic Contrast
Mega Dynamic Contrast Ratio delivers new levels of color and picture quality to your viewing experience with images that are real-to-life. A breathtaking Mega8 DCR contrast ratio shows blacks at their absolute darkest and pristine whites and other colors at their brightest. You will notice the crystal clear picture clarity. It is like explosions of colors that make other screens seem dull in comparison. Enjoy your multimedia content with the professionalism it deserves. -
Pivot
Change your monitor perspective using Samsung's innovative Pivot feature. It allows you to rotate your screen up to 90 degrees to match -
Swivel
Samsung's Swivel functionality ensures that the monitor can be easily and quickly re-adjusted, and is extremely useful when working in groups. -
Tilt
Set your monitor to the perfect angle with Samsung's Tilt functionality. It ensures that your monitor is always providing the most comfortable experience. -
Recycled Plastics
Samsung Business Monitors embrace the green movement by using some recycled plastics during the manufacturing process. -
Eco Certification - TCO Display certified
Meeting the strict environmental requirements of the TCO Display standard, the Samsung monitors represent the cutting-edge of responsible design and manufacture, ensuring the health of both users and the planet. -
Eco Certification - EPEAT
Upgrade to the greener Samsung LED Business Monitor, which comes with the Green Certificate from EPEAT. With reduced 'soft power' consumption, this eco-friendly monitor is perfect for business. -
Eco Certification - Energy Star
Minimize costs with Samsung's LED Business Monitor, which has been accredited with the Energy Star rating. With less power consumption, this monitor is good for business and the environment.
- Samsung S19C450BR - SC450 Series - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Matte black
- 40.7 cm x 21 cm x 36.9 cm
- 4.45 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, ISO 9241-307
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, power off timer, MagicColor, HDCP, MagicAngle, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 40.7 cm x 21 cm x 36.9 cm - with stand
- 4.45 kg
- VGA , DVI-D
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- -1/+95
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 40.7 cm - depth: 21 cm - height: 36.9 cm - weight: 4.45 kg , Without stand - width: 40.7 cm - depth: 5.5 cm - height: 33.6 cm
Sustainability Information
- ENERGY STAR Certified
