Your basket is empty
Samsung S19B150N 18.5 WIDE LED 1366 X 768 VGA Widescreen
Quicklinx: 82TTWS00 Mfr#: LS19B150NS/EN
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
  • Compatible with Windows 7
1 left in stock
£65.69 ex VAT
£78.82 inc VAT
See a more dramatic picture with great contrast
Be more efficient with brightness adjustment
Attractive glossy black design fits any surroundings
Adjust monitor tilt for comfort and better posture
Samsung S19B150N - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
High glossy black
44.5 cm x 17.7 cm x 34.8 cm - with stand
2.1 kg
Microsoft Certification
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
Display Type
Diagonal Size
18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
81 kHz
Video Bandwidth
95 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Sync on Green, power off timer, MagicTune, MagicColor, MagicBright 3, Mega Dynamic Contrast Ratio
High glossy black
2.1 kg
VGA
Mechanical
Tilt
Tilt Angle
-1/+20
1 x VGA cable
Power Supply
External
AC 120/230 V ( 50/60 Hz )
20 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - 44.5 cm x 17.7 cm x 34.8 cm x 2.1 kg , Without stand - 44.5 cm x 5.3 cm x 27.3 cm
EPEAT Compliant
EPEAT Gold
10 °C
10 - 80% (non-condensing)
Response Time: 5ms
Speakers: None
Colour: High glossy black
Brand: Samsung
Price Range Ex VAT: 50 - 100
