Six built-in speakers give this Soundbar the depth and power to deliver a warm and detailed audio experience. Inside are two tweeters that deliver crisp, clear high-frequency tones. A separate wireless subwoofer backs these up with a deep bass. All of this combines to create an ideal environment for enjoying studio-quality HD sound, getting you closer to the original performance than ever before.
Wirelessly attach speakers to this Soundbar to build a system designed around the way you listen. Create your own cinema-style wireless 4.1 system for your living room or play different music in different rooms with compatible Multiroom speakers.
Enjoy a more immersive sound experience with surround sound expansion technology. Feel like you are part of the action with lifelike sound that surrounds you on all levels. Enjoy cinema-style technology with powerful bass and natural tones that are a perfect match for your Samsung TV.
Dive into crystal clear and detailed sound
Six built-in speakers give this Soundbar the depth and power to deliver a warm and detailed audio experience. Inside are two tweeters that deliver crisp, clear high-frequency tones. A separate wireless subwoofer backs these up with a deep bass. All of this combines to create an ideal environment for enjoying studio-quality HD sound, getting you closer to the original performance than ever before. -
The most flexible way to grow your audio system
Wirelessly attach speakers to this Soundbar to build a system designed around the way you listen. Create your own cinema-style wireless 4.1 system for your living room or play different music in different rooms with compatible Multiroom speakers. -
Great cinematic surround sound
Enjoy a more immersive sound experience with surround sound expansion technology. Feel like you are part of the action with lifelike sound that surrounds you on all levels. Enjoy cinema-style technology with powerful bass and natural tones that are a perfect match for your Samsung TV. -
The wireless way to upgrade your TV
Get the freedom to connect your Soundbar to your Samsung TV automatically without wires, and enjoy superb powerful sound that brings programs, movies and music to life. TV has never sounded so good. -
Hide your sub out of view without worrying about wiring
Combine the simplicity of the Soundbar with the thunderous bass sound quality to give you a truly enriching sound environment. The supersonic sub-woofer that accompanies Samsung's Soundbar adds dynamic and rich bass levels to your listening experience. Its wire-free design makes it easy to set up and to adjust around the room to give you the best bass effect.
- Samsung HW-J651 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 4.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 320 Watt
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar , 1 x subwoofer
- Silver
- Built-in Decoders
- Dolby Digital
- Product Type
- USB-host
- Enclosure Colour
- Silver
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 320 Watt
- Amplifier
- Integrated
- Audio Return Channel (ARC) Capability
- Bluetooth, Wi-Fi
- Built-in Decoders
- Dolby Digital
- Audio Formats
- Additional Features
- Audio Return Channel (ARC), Anynet+, smartphone remote controlled, TV SoundConnect technology
- Speakers Included
- 1 x sound bar - wired , 1 x subwoofer - wireless
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB 2.0 (4 PIN USB Type A) , Audio line-in , SPDIF input (TOS Link)
- Included Accessories
- Remote control, wall mounting bracket
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg , Sound bar: 106 cm x 7.15 cm x 5.1 cm / 2.4 kg
