The GALAXY S4 Zoom, the only smartphone with 10x optical zoom. A state-of-the-art smartphone with a high-end compact camera. Combining the GALAXY S4 technology and advanced optics, for sharing your amazing creativity.
State-of-the-art design
Stunning curves, uncluttered design and comfortable to hold. Everything about the Galaxy S4 Zoom has been styled to perfection. -
10x optical zoom
Shoot close up or shoot from far away. Either way, your images will be perfectly sharp and display vivid, life-life color. Simply open up the fully retractable lens and capture life as it happens. -
Android Jelly Bean
Get up to speed with an operating system that's all about smoother, faster performance. Shine on all your social networks and explore a world of Android apps and games. -
Instant sharing: talk, shoot, share at the same time
Instantly launch the camera app and select photographic functions with the zoom ring. Then capture the perfect image and share it instantly. -
Quick launch & shortcut: instant access to multiple camera modes
Just a quick twist of the Galaxy S4 zoom's front-mounted zoom ring, followed by a quick touch of the display, lets you dial up different camera modes from: Auto, Gallery, Smart Mode, Manual, Program, and more with My mode. -
Optical zoom control: travel near or far with a zoom ring
The zoom control re-imagined. Optical zoom control replaces traditional dials and buttons with smooth, easy-to-operate digital controls. Professional-quality accuracy and unprecedented ease of use are just a quick twist of the zoom ring away, making it easy to capture wide-angle shots and create tight-focus effects. -
10x optical zoom: capture close-ups, even from far away
Bigger doesn't always mean better. The small-size/big-performance Galaxy S4 zoom is equipped with 10x optical zoom to let you capture clear images and beautiful, accurate color, even from far away. And thanks to the Galaxy S4 zoom's professional-quality optics and precise zoom-ring adjustment, you can take eye-popping close-ups, too - all without having to lug around heavy camera gear. -
16-megapixel BSI CMOS sensor: better low-light performance and motion capture
Advanced sensor technology makes your pictures come alive. The super-fast, super-sensitive 16-megapixel BSI (back side illuminated) CMOS sensor needs less light for proper exposure and quicker focus than conventional sensors. So even if a moment happens in the dimmest lighting conditions, your photos will capture everything. -
OIS: it remains perfectly still, even when you don't
Shooting in a hurry doesn't have to mean shooting blurry. The Galaxy S4 zoom's Optical Image Stabilization (OIS) system gives images crisp focus, even if you're not perfectly still. Don't miss a shot worrying about the right conditions. Click with confidence and create photos and video that come out sharp and clear - even in low-light situations, when zooming in for a shot, or while you're on the move. -
Photo Suggest: make the most of every journey with location-based suggestions
It's like a photo tour guide in your pocket. Photo Suggest instantly connects you to huge libraries of images taken by fellow photographers, to help you find and compose your best shots anywhere in the world. Bring more life to your photos - and more photos to your life - with leading social apps and widgets, including TourWrist, Panoramio, TripAdvisor and others. -
Smart Mode Suggest: optimal settings for anything
Capture everything life can throw at you, and still come back with amazing pictures. Smart Mode Suggest recognizes lighting conditions, scenery, and objects, and instantly recommends the optimal Smart Mode. -
Smart Mode: compose and capture shoots with the best possible settings
Stop worrying about settings, and start taking professional-quality artistic shots. A quick tap of the Smart Mode button gives you access to a wide range of special modes. Use Drama Shot to merge continuous shots of moving objects into a single composed image, or Action Freeze to instantly capture high-speed action.
- Samsung Galaxy S4 Zoom - white - 3G smartphone - 8 GB - GSM
- Product Type
- 3G smartphone
- Display
- OLED display - 960 x 540 pixels - 4.3" - Super AMOLED
- Processor
- 1.5 GHz (dual-core)
- Memory
- RAM 1.5 GB / 8 GB
- Supported Memory Card
- microSDXC slot - up to 64 GB
- Operating System
- Android 4.2 (Jelly Bean) with Samsung TouchWiz
- Main Camera
- 16 Megapixel - BSI-CMOS - f/3.1-6.3 - focus: automatic
- Service Provider
- Not specified
- Wireless Interface
- NFC, Bluetooth, Wi-Fi
- Messaging Services
- Google Talk, SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 780 minutes
- Standby Time
- Up to 570 hours
- White
- 63.5 mm x 15.4 mm x 125.5 mm
- 208 g
- Specific Absorption Rate (SAR)
- 0.14 W/kg (head) , 0.2 W/kg (body)
- SAR Category (Belgium)
- A
- Product Type
- Smartphone
- Form Factor
- Touch
- 63.5 mm
- 15.4 mm
- 125.5 mm
- 208 g
- Body Colour
- White
- SAR Value
- 0.2 W/kg (body), 0.14 W/kg (head)
- A
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 3G
- Service Provider
- Not specified
- Operating System
- User Interface
- Samsung TouchWiz
- Navigation
- A-GPS, GLONASS
- Input Device
- Multi-touch
Messaging & Internet
- Supported Social Networks and Blogs
- Twitter, Facebook, Google+
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- NFC, Bluetooth 4.0, IEEE 802.11a/b/g/n
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP
- Communication Features
- Mobile Email client, Internet browser
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor
- Additional Features
- DLNA Certified, Text-to-Speech (text recognition), sharing media via DLNA, Screen capture, Face Unlock, S Beam, Smart stay, Face tag, Group Play function, Samsung Link (AllShare Play), Zoom Ring control, In-Call Photo Share function
Organiser
- Personal Information Management
- Calendar, synchronization with PC, calculator, reminder, alarm clock with snooze, stopwatch, alarm clock
Media Player
- Supported Digital Audio Standards
- WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, AAC +, OGG, eAAC+, M4A, apt-X
- Supported Digital Video Standards
- MKV, VC-1, FLV, AVI, MPEG-4, WMV, 3GP, H.264, H.263, MP43
- Clock Speed
- 1.5 GHz
- Processor Core Qty
- Dual-core
- RAM
- 1.5 GB
- Internal Memory Capacity
- 8 GB
- User Memory
- 5 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 64 GB
Front Camera
- Special Effects
- Beauty face
Main Camera
- Sensor Resolution
- 16 Megapixel
- Sensor Type
- BSI-CMOS
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/3.1-6.3
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Self-Timer Delay
- Special Effects
- Sepia, sunset, fisheye, snow, landscape, Cartoon, Vignetting, Silhouette, Greyscale, Vintage
- Camera Modes
- Red-Eye Reduction, Sound & Shot, Drama Shot, Continuous shot, Animated photo, Kids shot, Smart mode suggest, Expert Mode (P/S/M/C)
- Face Detection
- Face detection, smile shutter, Best face function
- HDR Mode
- Auto HDR mode
- White Balance
- Automatic, presets
- Light Source
- Xenon flash
- Video Resolutions
- 1920 x 1080 (1080p)
- Best photo function, Anti-shake, blink detection
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 4.3"
- Display Resolution
- 960 x 540 pixels
- Connector Type
- Headset jack - mini-phone 3.5mm , MHL (Micro-USB) - 11 pin Micro-USB Type B
- Technology
- Lithium Ion
- Capacity
- 2330 mAh
- Talk Time
- 780 minutes
- Standby Time
- 570 hours
- Run Time Details
- Active online usage (WCDMA): up to 7 hrs , Active online usage (Wi-Fi): up to 9 hrs , Playback (video): up to 10 hrs , Playback (audio): up to 46 hrs , Talk (WCDMA): up to 780 min , Standby (WCDMA): up to 570 hrs
- Included Accessories
- Power adapter
