Samsung 960 EVO 1TB V-NAND M.2 SSD
Quicklinx: CJBGWS00 Mfr#: MZ-V6E1T0BW
Discover the next advancement in SSD technology with high-performance, highly reliable 960 EVO Series NVMe M.2 SSDs. Non-Volatile Memory Express (NVMe) with a Polaris controller outperforms SATA SSDs with exceptionally fast read/write speeds, and Samsung TurboWrite technology accelerates write speeds even further. Samsung's Magician software solution provides advanced functionality to manage, monitor and optimize drive performance.
  • Raise your performance expectations
    Enhanced bandwidth beyond the SATA interface provided by the NVMe interface, combined with the Polaris controller facilitates sequential Read/Write speeds. Plus, the Intelligent TurboWrite technology accelerates write speeds even further.
  • Rest easy with solid reliability
    The 960 EVO holds its own by boasting up the capacity model. Dynamic Thermal Guard prevents overheating, protecting your data and ensuring optimal performance.
  • Manage your drive like magic
    The 960 EVO comes with the Magician - an advanced software solution for users to monitor, manage and maintain the drive. Magician provides personalized firmware checking and additional functions tailored for individual user's drives. It even updates the firmware automatically to make sure that the drive's performance stays up to date.
Samsung 960 EVO MZ-V6E1T0BW - solid state drive - 1 TB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, V-NAND Technology, eDrive, NVM Express (NVMe), S.M.A.R.T., 256-bit AES, IEEE 1667
22.1 mm x 80 mm x 2.28 mm
9 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
22.1 mm
80 mm
2.28 mm
9 g
Performance
SSD Endurance
400 TB
Internal Data Rate
3200 MBps (read) / 1900 MBps (write)
Maximum 4KB Random Write
380000 IOPS
Maximum 4KB Random Read
360000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
1.2 Watt (idle) , 5.7 Watt (average) , 5 mW (sleep)
Software Included
Samsung Magician Software
Limited warranty - 3 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
