Samsung 512GB 850 Pro SATA 6GB/s 2.5" Solid State Drive
Quicklinx: 9MKGWS00 Mfr#: MZ-7KE512BW
The Samsung 850 PRO SSD redefines storage with the world's first drive based on 3D VNAND flash, offering exceptional read/write performance, reliability and power management efficiency. The 850 Pro delivers up to 2x the speed, density and endurance of conventional flash.
  • The World's First Consumer 3D V-NAND SSD
  • Ultimate Read/Write Performance
  • Enhanced Endurance and Reliability
  • Efficient Power Management
Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 470 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance
With an industry-leading 10 year, 150 TBW warranty, the 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them.
Featuring a 4th generation MEX Controller, the 850 PRO offers one of the most energy-efficient drives on the market, using up to 50% less power than traditional hard drives. It has the lowest active write power consumption and supports device sleep mode, which lowers power consumption to under 2mW.
  • 2.5" SATA III Solid State Drive
  • 512GB
  • SEQUENTIAL READ SPEED: Up to 550MB/s
  • SEQUENTIAL WRITE SPEED: Up to 520 MB/s
  • Ultimate read/write performance
    Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 520 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance.
  • Enhanced endurance and reliability
    The 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them.
  • Efficient power management
Samsung 850 PRO MZ-7KE512BW - solid state drive - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
Hardware Encryption
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Hardware Full Disk Encryption (FDE), TRIM support, Automatic Garbage Collection, DevSleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Dynamic Thermal Guard protection, RAPID mode support, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.86 mm
10 years warranty
512 GB
Hardware Encryption
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100 mm
6.86 mm
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
90000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.5 Watt (active) , 50 mW (idle) , 2 mW (sleep)
Software Included
Drivers & Utilities, Samsung Magician Software, Samsung Smart Migration Software, Samsung Drive Manager
Limited warranty - 10 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 0.5ms half-sine pulse
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
