Samsung 4TB M3 Portable 2.5" USB 3.0 Hard Drive - Black
Quicklinx: BGGFWS00 Mfr#: HX-M401TCB/G
The Samsung M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go. The durable black design stands up to the rigors of daily use.
PRODUCT HIGHLIGHTS
• Handy portable storage
• Durable black design
• SafetyKeyTM protection for your data
CONTENT
• M3 Portable External Hard Drive
• USB cable
• Quick Install Guide
• Software preloaded on the drive
• Electronic User Documentation (PDF)
OPERATING SYSTEM
• Windows 8/7/Vista, Mac OS X 10.4.8 or later
PERFORMANCE SPECIFICATION
• SuperSpeed USB 3.0 (Max): 4.8Gb/s
ENVIRONMENTAL SPECIFICATION
• Temperature (operating): 5° to 40°C (41° to 104°F)
• Temperature (nonoperating): –20° to 65°C (–4° to 149°F)
SOFTWARE
• AutoBackup personal backup solution
• Secure Drive for worry-free data security
• SecretZoneTM can encrypt data on the device
DRIVE WEIGHT & DIMENSION
• Weight (Max): 236g (4TB)
• Size: 82mm W x 118.2mm L x 19.85mm H (Max)
PACKAGED BOX WEIGHT & DIMENSION
• Weight: 373g (4TB)
• Size: 137mm W x 185mm L x 38.5mm H
WARRANTY
• 3-year limited warranty
TECH SUPPORT
• Online at www.seagate.com
Samsung M3 Portable STSHX-M401TCB - hard drive - 4 TB - USB 3.0
Hard drive - external (portable)
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Samsung Auto Backup, SafetyKey, SecretZone, Secure Drive
Power Source
USB bus
Enclosure Colour
82 mm x 118.2 mm x 19.85 mm
236 g
3-year warranty
4 TB
USB 3.0
82 mm
118.2 mm
19.85 mm
236 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Max Data Transfer Rate
600 MB/s
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8
1 x USB cable
Enclosure Colour
Limited warranty - 3 years
5 °C
