The Samsung M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go. The durable black design stands up to the rigors of daily use.
PRODUCT HIGHLIGHTS
• Handy portable storage
• Durable black design
• SafetyKeyTM protection for your data
CONTENT
• M3 Portable External Hard Drive
• USB cable
• Quick Install Guide
• Software preloaded on the drive
• Electronic User Documentation (PDF)
OPERATING SYSTEM
• Windows 8/7/Vista, Mac OS X 10.4.8 or later
PERFORMANCE SPECIFICATION
• SuperSpeed USB 3.0 (Max): 4.8Gb/s
ENVIRONMENTAL SPECIFICATION
• Temperature (operating): 5° to 40°C (41° to 104°F)
• Temperature (nonoperating): –20° to 65°C (–4° to 149°F)
SOFTWARE
• AutoBackup personal backup solution
• Secure Drive for worry-free data security
• SecretZoneTM can encrypt data on the device
DRIVE WEIGHT & DIMENSION
• Weight (Max): 236g (4TB)
• Size: 82mm W x 118.2mm L x 19.85mm H (Max)
PACKAGED BOX WEIGHT & DIMENSION
• Weight: 373g (4TB)
• Size: 137mm W x 185mm L x 38.5mm H
WARRANTY
• 3-year limited warranty
TECH SUPPORT
• Online at www.seagate.com
- Samsung M3 Portable STSHX-M401TCB - hard drive - 4 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 4 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Samsung Auto Backup, SafetyKey, SecretZone, Secure Drive
- Power Source
- USB bus
- Enclosure Colour
- Black
- 82 mm x 118.2 mm x 19.85 mm
- 236 g
- 3-year warranty
- Capacity
- 4 TB
- Interface
- USB 3.0
- 82 mm
- 118.2 mm
- 19.85 mm
- 236 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 600 MB/s
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 40 °C
