Samsung 40" K5500 Series 1080p Full HD LED Smart TV
Quicklinx: C1XJWS00 Mfr#: UE40K5500AKXXU
  • 1080p
  • Enjoy crisp and clear Full HD picture quality
  • Seamlessly access all your entertainment with the Smart Hub
  • Experience a clean picture with Ultra Clean View
Enjoy crisp and clear Full HD picture quality with vibrant images delivered through Wide Colour Enhancer technology. Digital Clean View technology analyses the quality of the signal input to improve your viewing experience and deliver brilliant picture quality.
Seamlessly access all your entertainment sources through the Smartest TV on the Planet. Watch your most loved TV shows using the TV guide, switch to binge on UHD box sets through Netflix, Amazon Instant Video1 or catch up with shows you have missed through our variety of content partners2 – all of this is doable without interrupting what you are currently watching and all from the Smart Hub home screen. 3Just 3 clicks to your favourite content.
  • Full HD resolution
    Enjoy crisp and clear Full HD picture quality with vibrant images delivered through Wide Color Enhancer technology. Digital Clean View technology analyzes the quality of the signal input to improve your viewing experience and deliver brilliant picture quality.
  • Ultra Clean View
    Ultra Clean View analyzes the input signal and removes detected noise from the feed. No matter what quality the signal Ultra Clean View improves what you see.
  • Enhanced contrast for sharper details
    Micro Dimming technology divides the TV screen into hundreds of small zones, analyzing each one independently to adjust color, brightness and sharpness so you can experience better shadow detail and accurate color when watching your favorite video content.
  • Deeper contrasts bring images to life
    Experience the realistic TV viewing on a flat screen with the Contrast Enhancer. It adjusts contrast intelligently on different parts of the screen to heighten the dramatic effect.
  • Enjoy enhanced colors and better images
    Using an advanced picture quality improvement algorithm, Samsung's Wide Color Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colors as they were meant to be.
  • Faster speeds, stronger performance
    Experience a fast and fluid browsing experience with quad-core processor. Access a variety of different content sources, switch between apps, stream content, play online video games and multi-task seamlessly from the Smart Hub with ease.
  • Dive into your video content
    Motion Rate 60 offers immersive viewing with flicker-free video content. The amazing refresh rate and backlight technology will keep you at the edge of your seat with fast and seamless video.
  • Simple and fast wireless connection
    The built-in Wireless LAN lets you connect your Smart TV to the Internet without the tangle of cables. With the streamlined connections, now you can really enjoy your TV's outstanding design.
  • Plug your entertainment into the TV
    Using ConnectShare, you can watch a variety of content in one simple step. Just plug your USB or HDD into the TV and enjoy your movies, music, and pictures on the big screen.
Samsung UE40K5500AK K5500 Series - 40" LED-backlit LCD TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
40"
Dark titan
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
400 Picture Quality Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight Micro Dimming Pro
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T2
Internet Streaming Services
HbbTV
Multi-channel Preview
Picture-in-picture (PIP)
USB
2 ports
Remote control, batteries, Samsung TM1240A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
95 Watt
Power Consumption (On mode)
54 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
75 kWh
91.76 cm x 5.5 cm x 53.9 cm
8.6 kg
Energy Class
Class A
95 Watt
54 W
75 kWh
Diagonal Class
40"
Series
K5500 Series
Video Processor
Quad-Core
TV Tuner Presence
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
Modes
Game mode, Natural Mode, Sports Mode Advanced, Cinema mode
Design
Very Narrow Bezel Design (VNB)
Dimensions
Without stand
91.76 cm
5.5 cm
53.9 cm
8.6 kg
Enclosure Colour
Dark titan
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, E-Manual, Instant On, Multiroom Compatible, Accessibility Zoom, Accessibility High contrast
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Output Power / Total
20 Watt
Audio Return Channel (ARC)
Speakers
2 x main channel speaker
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, ConnectShare, Sound Share
HbbTV
Supported Consumer Electronics Control (CEC)
Anynet Plus
DLNA
Connector Type
3 x HDMI , 2 x USB 2.0 , LAN , Digital audio output (optical) , Composite video / component video input , Audio line-in
Batteries, Samsung TM1240A remote control
CEC
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 91.76 cm x 5.5 cm x 53.9 cm x 8.6 kg , Panel with stand - 91.76 cm x 25 cm x 60.4 cm x 9.6 kg
Width (Shipping)
105.5 cm
Depth (Shipping)
12.1 cm
Height (Shipping)
64 cm
Weight (Shipping)
12.4 kg
C1XJ C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
C1XJ C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
