Samsung's popular 5 series H5000 TV displays a picture quality that's crisp, clear, and breathtakingly life-like. Enjoy movies, drama and sporting events in Full HD from the comfort of your home and feel like you're part of the crowd with Samsung's Football mode.
Samsung's HD Ready TV displays a picture quality that's crisp, clear and breathtakingly life-like to create an immersive TV experience.
Freeview HD is a free to air digital service built into your TV to offer more choice. With free access to over 50 standard definition TV channels and 4 HD channels (including ITV HD, BBC One HD, BBC HD and 4 HD), now there's always something to watch!
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer Plus drastically improves the quality of any image and uncovers hidden details. Now see colours as they were meant to be seen with Wide Colour Enhancer Plus.
Feel like you're actually in the stadium cheering on your favourite team with Samsung's Football Mode. At the press of a button it optimises picture and sound settings for a better football viewing experience.
ConnectShare Movie lets you watch videos, play music or view photos from a USB connection without needing to use a PC. Simply plug your USB drive directly into your Samsung TV's USB port and watch on the big screen with friends and family.
Samsung Slim Design. Encased in an attractive black edge frame combined with an appealing black rectangular stand, this beautifully designed TV will complement any room in your home.
2 x HDMI connections give you superior picture and sound from your HD source. The High-Definition Multimedia Interface (HDMI) is a digital connection that can transmit HD video and audio over a single cable. Use it to optimize the image quality when you connect your TV to high-definition sources such as an HD cable TV, satellite receiver, or Blu-ray player.
Sensational Full HD picture quality
Feel the sensation of Full HD picture quality. -
Full HD 1080p
Crisper, clearer, and breathtakingly life-like picture quality. -
Freeview HD
Enjoy over 50 standard definition TV channels and 4 HD channels for free. -
Wide Color Enhancer Plus
See richer colors as they were meant to be seen. -
Football Mode
With the touch of a button optimize video and audio settings, feel like you're in the stadium. -
ConnectShare Movie
Watch videos, play music or view photos from your USB device.
- Samsung UE40H5000AK - 40" LED TV
- Energy Class
- Class A+
- Product Type
- LED-backlit LCD TV
- 88 Watt
- Power Consumption (On mode)
- 45 W
- Energy Consumption per Year
- 66 kWh
- Diagonal Size
- 40"
- 90.82 cm x 6.48 cm x 53.29 cm - without stand
- 7.6 kg
- Black
- Resolution
- 1366 x 768
- Motion Enhancement Technology
- 100 Clear Motion Rate
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 port(s)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Clock, Auto Power Off, game mode, HyperReal Engine, ConnectShare Movie, Wide Color Enhancer Plus, Eco Sensor, USB Cloning, E-Manual, Caption (Subtitle), Embeded POP, Luxe Line Design, Football Mode Basic
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound, DTS Premium Sound 5.1
- USB Port
- Yes , 1 port(s)
- Remote Control
- Remote control
- Power
- AC 230V ( 50/60 Hz )
- Product Type
- Energy Class
- Class A+
- 88 Watt
- 45 W
- 66 kWh
- Diagonal Size
- 40"
- Series
- 5 Series
- TV Tuner
- Video Interface
- HDMI Ports Qty
- 2 port(s)
- HDCP Compatible
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 90.82 cm
- 6.48 cm
- 53.29 cm
- 7.6 kg
- Enclosure Colour
- Black
Display
- LED backlight
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- Digital TV Service
- FREEVIEW HD
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- Yes , 1 port(s)
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1240A
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Auto Volume Leveller (AVL)
- Speaker(s)
- 2 x main channel speaker - built-in - 10 Watt
- Driver Details
- Main channel speaker : full-range driver
- Connector Type
- 2 x HDMI ( 19 pin HDMI Type A ) , 1 x composite video / component video input ( RCA phono x 3 ) , 1 x digital audio output (optical) ( TOS Link ) , 1 x USB 2.0 ( 4 PIN USB Type A ) , 1 x SCART ( 21 PIN SCART ) , 1 x headphones ( mini-phone stereo 3.5 mm ) , 1 x audio input ( RCA phono x 2 )
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 90.82 cm x 6.48 cm x 53.29 cm x 7.6 kg , Panel with stand - 90.82 cm x 19.64 cm x 57.82 cm x 8.3 kg
- Width (Shipping)
- 110 cm
- Depth (Shipping)
- 12 cm
- Height (Shipping)
- 60 cm
- Weight (Shipping)
- 10.7 kg
