Samsung CF390 27" 4ms HDMI Curved Monitor
CLEARANCE!
Clearance
Quicklinx: C3M5WS00 Mfr#: LC27F390FHUXEN
Select:
  • 27"
All of Samsung's curved monitors include a host of features that further reduce reflectance and visual fatigue, enabling users to view their screens for longer periods. The CF390 displays leverage Samsung's flicker-free technology to prevent interruptions that can strain users' eyes. A complementary Eye Saver Mode setting further protects audiences from exposure to harmful blue light emissions. To benefit gamers and at-home entertainment users, all three displays include embedded AMD FreeSync technology over HDMI functionality that synchronizes screen refresh rates with users' AMD graphics cards to reduce input latency, stutter and lag when viewing interactive video content. To deliver a more uniform presentation, Samsung's CF390 monitors offer a wide 178-degree viewing angle. This expanded visibility ensures that users can enjoy the full visual detail scope from multiple locations in the room, with less eye movement required.
By combining its optimized curvature and wide-angle viewing with premium color presentation and accuracy maintenance features, Samsung's curved displays bring even the most minor visual details to life - even in traditionally environments for watching movies and playing video games. The displays' 3,000:1 static contrast ratio is nearly three times higher than that of standard monitor alternatives, and presents content with deeper blacks and more pristine whites. All three curved monitors are reinforced with Samsung's industry-leading Vertical Alignment (VA) panel technology to reduce backlight bleed and produce a more complete, high-quality picture. For gaming users, Samsung's Game mode setting automatically adjusts picture conditions to become lighter or darker as dictated by gameplay, while also minimizing screen stuttering and tearing. These benefits, combined with the displays' tight curve radius, give gamers a sense that the screen is surrounding them to inspire a more realistic experience.
Samsung's CF390 curved monitors feature a boundless, thin-bezel design that eliminates viewing borders and draws audiences into a distraction-free environment. This sophisticated boundless design facilitates the illusion that on-screen content is floating in mid-air and fosters a more immersive and captivating presentation. Additionally, Samsung's monitors are built to be both practical and attractive, making them a compatible addition to any desktop or home entertainment setting. All three displays feature a metallic silver front and glossy white back that accentuate their curved structure. A circular stand elevates the look of the displays' base while simultaneously providing stable support. Likewise, CF390 users can easily adjust their screen to the ideal height and viewing angle with the displays' ergonomic tilt and swivel components.
Samsung C27F390FHU - CF390 Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
29 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Shiny black
62.29 cm x 24.77 cm x 46.25 cm
4.4 kg
Display Type
Energy Class
Class G
35 kWh
Diagonal Size
27"
Curved Screen
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
Shiny black
62.29 cm x 24.77 cm x 46.25 cm - with stand
4.4 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
75 x 75 mm
Stand
Input Voltage
AC 120/230 V
29 W
29 kWh/1000h
Power Consumption Sleep
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 62.29 cm - depth: 24.77 cm - height: 46.25 cm - weight: 4.4 kg , Without stand - width: 62.29 cm - depth: 9.44 cm - height: 36.76 cm - weight: 3.6 kg
Shipping Width
68.1 cm
Shipping Depth
17.9 cm
Shipping Height
45.2 cm
Shipping Weight
6.1 kg
10 °C
10 - 80% (non-condensing)
C3M5 StarTech.com Articulating Monitor Arm In Stock £132.69
C3M5 StarTech.com Dual Monitor Stand In Stock £91.00
C3M5 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
C3M5 StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
