Samsung 32" 1920x1080 DVI HDMI LED-backlit LCD Large Format Display
Quicklinx: 9KCWWS00 Mfr#: LH32DMDPLGC/EN
  • 1080p
The Samsung DM32D delivers 24/7 reliability for continuous operation. Create stunning and seamless video walls in Full HD resolution thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. Combined with a sleek industrial design and slim 2" chassis depth, you can captivate your audience in a moment and leave a lasting impression on the 32" screen.
  • Reliable 24/7 continuous operation
    Samsung cooling technologies allow your message to be displayed with highly reliable 24/7 continuous operation. So business users can meet 24/7 operating requirements in venues ranging from retail stores to command and control facilities.
  • Enhanced SSP with quad-core processor
    Experience 2x SoC performance thanks to SSP with a quad-core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • Sleek industrial design
    Slim-direct LED backlight technology delivers a sleek industrial design with a 2" chassis depth that is combined with a symmetrical 10.5 mm bezel for an elegant look. LED also slims your TCO thanks to up to 50% energy savings over CCFL.
  • Full connectivity
    Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience. Connections include D-sub, component, composite, HDMI, DVI, USB, SD, RS232C in/out, IR in/out and more.
  • Built-in Wi-Fi
    Expanding your versatility even more, you can enjoy easy media sharing and screen control with built-in Wi-Fi and AllShare Cast. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display.
  • Clean UI design
    A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
Samsung DM32D DM-D Series - 32" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Supported Memory Cards
SD Memory Card
Remote control
Voltage
Energy Class
Class C
77 Watt
Power Consumption (On mode)
60 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
88 kWh
72.14 cm x 4.99 cm x 42.03 cm
4.84 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
77 Watt
60 W
88 kWh
Diagonal Class
32"
Commercial Use
Series
DM-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
72.14 cm
4.99 cm
42.03 cm
4.84 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.12125 x 0.36375mm
Response Time
8 ms
Commercial Features
Pivot, MagicInfo, LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Remote control
Audio System
Built-in speaker
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, IRAM, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
80.1 cm
Depth (Shipping)
11.8 cm
Height (Shipping)
47 cm
Weight (Shipping)
5.9 kg
10 - 80%
