Samsung 2TB Momentus Spinpoint M9T 2.5" SATA 6GB/s 9.5mm Hard Drive
2TB 2.5" 9.5MM OEM DRIVE IS NOW AVAILABLE!
Quicklinx: 9MXRWS00 Mfr#: ST2000LM003
The Samsung Spinpoint M9T mobile SATA drive delivers high capacity in a thin design to give customers the ideal solution for external and mobile applications. The 2.5-inch drive is just 9.5mm thin and available in capacities of 1.5TB and 2TB.
  • Max. 667GB formatted capacity per disk
  • SATA Native Command Queuing feature
  • TuMR/PMR head with FOD technology
  • SATA 6Gb/s interface support
  • Load/unload head technology
  • ATA Security Mode feature set
  • ATA S.M.A.R.T. feature set
  • SilentSeek™
  • NoiseGuard™
  • Interface: SATA 6Gb/s (3Gb/s, 1.5Gb/s)
  • Rotational Speed: 5400-RPM class
  • Cache: 32MB
  • Average Seek Time (typical): 12ms
  • Average Latency: 5.6ms
  • Drive Ready Time (typical)2: 3.5ms
  • Media to/from Buffer (max): 169MB/s
  • Buffer to/from Host (max): 600MB/s
  • Nonrecoverable Read Error: 1 sector in 10E14 bits
  • Controlled Ramp Load/Unload: >600,000
  • Idle: 2.5 bels
  • Performance Seek: 2.7 bels
  • Voltage: +5V ± 5%
  • Spin-up Current (max): 1000 mA
  • Read/Write (avg)3: 2.3W
  • Low Power Idle (avg): 0.7W
  • Standby (avg): 0.18W
  • Sleep (avg): 0.18W
  • Height: 9.5mm ±0.2mm (0.374in ±0.008in)
  • Width: 69.85mm ±0.25mm (2.75in ±0.010in)
  • Length: 100.35mm +0.2/-0.25mm (3.951mm +0.008/-0.010in)
  • Weight (max): 130g (0.29lb)
Samsung SpinPoint M9T ST2000LM003 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
5400 rpm
Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology, S.M.A.R.T.
69.85 mm x 100.35 mm x 9.5 mm
130 g
Microsoft Certification
Compatible with Windows 7
2 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
32 MB
69.85 mm
100.35 mm
9.5 mm
130 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
169 MBps
Seek Time
12 ms (average)
Average Latency
5.6 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
60 °C
5 - 90% (non-condensing)
Shock Tolerance
300 g @ 2ms half-sine pulse (operating) / 900 g @ 1ms half-sine pulse (non-operating)
Vibration Tolerance
1.5 g @ RMS (random) (operating)
Resources
The following resources are available for the Samsung 2TB Momentus Spinpoint M9T 2.5" SATA 6GB/s 9.5mm Hard Drive
