Your basket is empty
Samsung 2TB M3 Slimline Portable USB 3.0 Hard Drive Black
Quicklinx: 9382WS00 Mfr#: HX-M201TCB/G
Form Factor: 2.5"
Capacity: 2TB
Interface: SuperSpeed USB
More than 50 in stock
£58.33 ex VAT
£69.99 inc VAT
Express delivery Order within the next 8 hours for delivery tomorrow
The Samsung M3 Portable External Hard Drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity up to 2TB. The durable black design stands up to the rigors of daily use.
PRODUCT HIGHLIGHTS
- Handy portable storage
- Durable black design
-SafetyKeyTM protection for your data
Box Contains
- Samsung Hard Drive
- USB Cable
- Quick Install Guide
- User Software (preloaded)
- Electronic User Documentation (PDF)
SOFTWARE
- AutoBackup personal backup solution
- Secure Drive for worry-free data security
- SecretZoneTM can encrypt data on the device
OPERATING SYSTEM
Windows 8/7/Vista/XP, Mac OS X 10.4.8 or later
Samsung M3 Portable STSHX-M201TCB - hard drive - 2 TB - USB 3.0
Hard drive - external ( portable )
2 TB
2.5"
USB 3.0
Samsung Auto Backup, SafetyKey, SecretZone, Secure Drive
Power Source
USB bus
Enclosure Colour
8.2 cm x 11.2 cm x 1.75 cm
169 g
3 years warranty
2 TB
2.5"
USB 3.0
8.2 cm
11.2 cm
1.75 cm
169 g
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable
Enclosure Colour
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
Form Factor: 2.5"
Capacity: 2TB
Brand: Samsung
Price Range Ex VAT: 50 - 100
