Samsung 256GB 950 PRO Series M.2 NVME PCIE SSD
LOWER LATENCY LEVELS!
Quicklinx: BQRTWS00 Mfr#: MZ-V5P256BW
If you're a heavy workload professional searching for an SSD with uncompromising power and performance, look no further. The next-generation Samsung 950 PRO delivers exceptional performance for professionals. This cutting-edge V-NAND-based NVMe SSD supports PCI Express Gen 3 x 4 lanes, providing a higher bandwidth and lower latency to process a massive amount more data than SATA SSDs. Presented in a compact M.2 form factor, the future-oriented 950 PRO is ideal for professionals using high-end PCs and workstations.
  • Experience a next-generation SSD today
    Equipped with the enhanced bandwidth of the NVMe interface, the 950 PRO is ideal for intensive workloads, such as computer-aided design, data analysis and engineering simulations. It outperforms SATA SSDs by over 4,5 times in sequential read and by over 2.5 times in sequential write, delivering the speeds of 2500 MB/s and 1500 MB/s respectively.
  • Save power while maintaining peak performance
    If you're in the midst of performing a complex data analysis or engineering simulation on your laptop, you surely don't want to run out your battery. Compared to SATA SSD power consumption, the 950 PRO is up to 1,5 times more power efficient, so your battery will last longer and maintain superior performance levels.
  • Maximize endurance under heavy workloads
    The innovative V-NAND technology in the 950 PRO increases endurance and prolongs the lifespan with insulators that cause less stress and are more resistant to wear under heavy client workloads over a 5-year period. The 950 PRO also features Dynamic Thermal Throttling Protection technology, which controls the temperature of the device to reduce overheating and maintain a high level of sustained performance.
Samsung 950 PRO MZ-V5P256BW - SSD - 256 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
256 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
Buffer Size
512 MB
TRIM support, sleep mode, Thermal throttling, Auto Garbage Collection Algorithm, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
22.15 mm x 80.15 mm x 2.38 mm
10 g
5-year warranty
256 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
Buffer Size
512 MB
22.15 mm
80.15 mm
2.38 mm
10 g
Performance
SSD Endurance
200 TB
Internal Data Rate
2200 MBps (read) / 900 MBps (write)
Maximum 4KB Random Write
85000 IOPS
Maximum 4KB Random Read
270000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
5.1 Watt (average) , 6.4 Watt (maximum)
Software Included
Samsung Magician Software
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
