Your basket is empty
Samsung 250 SHT CASSET FOR ML-2850& ML-2851
Quicklinx: 7FZFWS00 Mfr#: ML-S2850A/SEE
Type: Media tray
Increase your printing efficiency with an extra legal tray that holds up to 250 sheets and is easily attachable to your Samsung printer.
Samsung ML-S2850A - media tray - 250 sheets
Media tray
Total Media Capacity
250 sheets
ML-2850D, 2851ND, 2855ND
Media tray
250 sheets
Samsung ML-2850D, 2851ND, 2855ND
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 90 day warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 7FZF 007243
Condition: aged stock clearance
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £5.21
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Media tray
Brand: Samsung
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
