Your basket is empty
Samsung 1TB M3 Portable USB 3.0 Hard Drive Black
Quicklinx: 88GQWS00 Mfr#: HX-M101TCB/G
Form Factor: 2.5"
Capacity: 1TB
Interface: SuperSpeed USB
More than 50 in stock
£39.99 ex VAT
£47.98 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
The Samsung M3 Portable External Hard Drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity of 1TB. The durable black design stands up to the rigors of daily use.
  • Handy portable storage
  • Durable black design
  • SafetyKey protection for your data
Contents
  • M3 Portable External Hard Drive
  • USB cable
  • Quick Install Guide
  • Software preloaded on the drive
  • Electronic User Documentation (PDF)
  • Windows 7/Vista/XP, Mac OS X 10.4.8 or later
  • SuperSpeed USB 3.0 (Max): 4.8Gb/s
  • Temperature (operating): 5° to 40°C (41° to 104°F)
  • Temperature (nonoperating): -20° to 65°C (-4° to 149°F)
  • Weight (Max): 151g (1TB)
  • Height (Max): 19.6mm (1TB)
  • Width: 82mm
  • Length: 112mm
  • 3-year limited warranty
Software
  • AutoBackup personal backup solution
  • Secure Manager for worry-free data security
  • SecretZoneTM can encrypt data on the device
Samsung M3 Portable STSHX-M101TCB - hard drive - 1 TB - USB 3.0
Hard drive - external ( portable )
1 TB
2.5"
USB 3.0
Samsung Auto Backup, SafetyKey, SecretZone
Power Source
USB bus
Enclosure Colour
8.2 cm x 11.2 cm x 2 cm
151 g
3 years warranty
1 TB
2.5"
USB 3.0
8.2 cm
11.2 cm
2 cm
151 g
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
1 x USB cable
Enclosure Colour
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
Resources
The following resources are available for the Samsung 1TB M3 Portable USB 3.0 Hard Drive Black
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 88GQ 027014
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £34.29
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Form Factor: 2.5"
Capacity: 1TB
Brand: Samsung
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
