Samsung 1TB 850 EVO Series SATA 6Gb/s 2.5" SSD
Quicklinx: B088WS00 Mfr#: MZ-75E1T0BW/EU
  • SATA 6Gb/s SSD for Client PCs
  • 2.5 inch form factor
  • Samsung 32 layer 3D V-NAND
  • Samsung Magician Software for SSD management
  • Samsung Data Migration Software
3D V-NAND Technology and THE SAMSUNG SSD 850 EVO
Samsung's unique and innovative 3D V-NAND flash memory architecture is a breakthrough in overcoming the density limitations, performance and endurance of today's conventional planar NAND architecture. 3D VNAND is fabricated by stacking 32 cell layers vertically over one another rather than decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in higher density and better performance utilizing a smaller footprint.
The 850 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.
Optimized performance for everyday computing experiences
Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides not only more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds for the 120/250 GB models as well. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance in all capacities. This comes with optimized random read and write performance on all QD and improved QD1 and QD2 random performance for Client PC usage.
Reinforcement of TurboWrite Technology
In the early stages of the 840 EVO, Samsung adopted sequential write performance first. With TurboWrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at "After TurboWrite" speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads.
For the 850 EVO, enhanced TurboWrite technology applied to random write speeds up to 1.9x faster for the 120 GB model and 1.25x faster for the 250GB model over the 840 EVO.
Guaranteed endurance
The 850 EVO delivers guaranteed endurance and reliability by doubling the TBW compared to the previous generation 840 EVO backed by an industry leading 5 year warranty. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do. The 850 EVO guarantees a 5 year limited warranty or 75TBW for 120GB and 250GB, 150TBW for 500GB and 1TB.
Enhanced reliability with improved sustained performance
With enhanced reliability through improved sustained performance, the 850 EVO assures longterm dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.
Advanced data encryption
The 850 EVO provides the same data encryption feature as the 840 EVO does. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardwarebased encryption engine to ensure that your personal files remain secure. Being hardwarebased, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide "How to use security features". Furthermore, you can erase or initialize data with the crypto erase service with PSID.
Unless marked as upgrade kits Samsung SSDs are Basic kits and include just the SSDs and no cabling or connectors
  • Optimized performance for everyday computing experiences
    Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides amazing user experience than 840 EVO. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance.
  • Guaranteed endurance
    The 850 EVO delivers guaranteed endurance and reliability. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do.
  • Enhanced reliability with improved sustained performance
    With enhanced reliability through improved sustained performance, the 850 EVO assures long term dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.
  • Advanced data encryption
    Self-Encrypting Drive (SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide "How to use security features". Furthermore, you can erase or initialize data with the crypto erase service with PSID.
  • Efficient power management for all PC applications
    Power consumption affects everyone. With 850 EVO's Device Sleep at a highly efficient 2mW you get longer battery life on your notebook thanks to a controller optimized for 3D V-NAND. With the 850 EVO you can work and play longer without having to plug in.
Samsung 850 EVO MZ-75E1T0 - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
Hardware Encryption
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
1 GB
Hardware Full Disk Encryption (FDE), TRIM support, Garbage Collection technology, DRAM cache, DevSleep mode, 3D V-NAND Technology, TurboWrite Technology, Low Power DDR2 SDRAM Cache, Samsung MEX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
66 g
5-year warranty
1 TB
Hardware Encryption
2.5"
SATA 6Gb/s
Buffer Size
1 GB
69.85 mm
100 mm
6.8 mm
66 g
Performance
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
98000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
50 mW (idle) , 4 mW (sleep) , 3.7 Watt (read) , 4.4 Watt (write)
Software Included
Samsung Magician Software, Samsung Data Migration
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Resources
The following resources are available for the Samsung 1TB 850 EVO Series SATA 6Gb/s 2.5" SSD
