Samsung 128GB 2.5 inch SATA 3 PM851 Samsung SSD
Quicklinx: BF46WS00 Mfr#: MZ-7TE128HMGR-0000
As the world's #1 DRAM, NAND Flash, and SSD supplier, Samsung has industry-leading engineering resources, design expertise and manufacturing prowess, as well as some of the most stringent quality control standards. All of this coalesces into producing an SSD which delivers the endurance that power users demand. Reliability is inherent in the design of the Samsung PM851, with endurance levels to assure extended long-term performance and extremely low error rates, even for devices that never stop running.
The Samsung PM851 Mobile/Client Edition features stunning design and precision engineering - inside and out. With thicknesses from 7 mm to as low as 2.4 mm, it can be easily installed in most ultrabooks, notebooks, video recorders, etc. Like other Samsung SSDs, it's designed and built completely in-house, rather than sourcing a hodge-podge of generic parts from the market. The Samsung PM851 Mobile/Client Edition uses the latest in-house NAND Flash and an advanced in-house controller to deliver superior performance, exceptional reliability and minimal power drain.
Samsung's PM851 Mobile/Client Edition offers superior sequential reads (up to 540 MB/s), and a fast sequential write speed of 410 MB/s. The PM851's random read and write levels are also first-class. The drive is an ideal solution for performancecentric workloads, such as multi-tasking between several programs simultaneously, complex data manipulation and highperformance gaming.
  • Superior endurance and reliability
    As the world's #1 DRAM, NAND flash, and SSD supplier, Samsung has industry-leading engineering resources, design expertise and manufacturing prowess, as well as some of the most stringent quality control standards. All of this coalesces into producing an SSD which delivers the endurance that power users demand. Reliability is inherent in the design of the Samsung PM851, with endurance levels to assure extended long-term performance and extremely low error rates, even for devices that never stop running.
  • Industry-leading design
  • Outstanding performance in PC applications
    Samsung's PM851 Mobile/Client Edition offers superior sequential reads, and a fast sequential write speed of 410 MB/s. The PM851's random read and write levels are also first-class. The drive is an ideal solution for performancecentric workloads, such as multi-tasking between several programs simultaneously, complex data manipulation and highperformance gaming.
  • Increased capacity and security
    The Samsung PM851 Mobile/Client Edition is designed to ensure that sensitive data is secure. Samsung's PM851 protects your data with AES 256-bit encryption, eliminating any concerns or uncertainties about data theft.
Samsung PM851 MZ7TE128HMGR - SSD - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), Device Initiated Power Management (DIPM), DevSleep mode, Samsung Toggle DDR NAND Flash memory, 256-bit AES
69.85 mm x 100.2 mm x 6.8 mm
45 g
128 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100.2 mm
6.8 mm
45 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 140 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
35000 IOPS
Reliability
MTBF
1,500,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
250 mW (active) , 50 mW (idle) , 2 mW (sleep)
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
