The Samsung SSD840 EVO is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MEX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
- Capacity: 120GB
- Sequential Read: 540MB/s
- Sequential Write: 410MB/s
- Random Read (QD32, 4KB): 94,000 IOPS
- Random Write (QD32, 4KB): 35,000 IOPS
- Random Read (QD1, 4KB): 10,000 IOPS
- Random Write (QD1, 4KB): 33,000 IOPS
- Warranty: 3 Year
Simple, 3-step upgrade solution
Don't waste your time & money by changing PCs. With its simple upgrade solution, Samsung's 840 is the single best upgrade for your PC and will deliver a whole PC experience. There is nothing to fear, because a simple, 3-step process will easily migrate all of your existing data. The much-improved magician software makes it convenient to maintain your SSD at its best condition. -
SSDs save time, letting you do more of what you love
With the Samsung 840, photo editing programs load twice as quickly and video clips render 30% faster than with an HDD. An 840 series SSD helps you get work done and out to family and friends in no time, leaving extra time to do more of what you love. Spend less time in front of the computer and more time with the people you love doing the things you want. -
Industry-leading reliability
From the world's leading storage engineers maker of SSD components, Samsung's SSD 840 series delivers rock-solid reliability and sustained high performance over time and under heavy use. -
Ultra low power consumption for longer battery life
Best-in-class power management technology delivers significant power savings and reliable performance. Samsung's SSD 840 series uses LPDDR2 cache memory that consumes 30% less power when active and 93% less power when idle than DDR2 memory while offering higher performance. With 30 minutes longer battery life, Samsung's SSD 840 series lets you get more from your mobile experience. -
Keep your data safe with Self-Encrypting Drive (SED) technology
Gain peace of mind without sacrificing performance, knowing that your data is protected with 256-bit AES hardware-based encryption. Samsung's SSD 840 applies data encryption automatically, and you can re-purpose your drive or dispose of your data simply by erasing the encryption key. -
Unbeatable performance with up to 300 % upgraded speed
Don't get frustrated by your sluggish PC anymore! You can now REVIVE your aging PC with Samsung SSD 840. SSD 840 has much higher random/sequential speeds than HDD. This makes it possible for users to carry on with multiple computing activities more quickly and stable, from booting, uploading or copying files. The SSD 840 reduces boot time from the regular 2-minute mark by 65%. It also speeds up file-transfer. In fact, it only takes 30 seconds to copy an entire video file, while it takes up to 100 seconds on a regular HDD.
- Samsung 840 EVO MZ-7TE120 - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- TRIM support, Automatic Garbage Collection, Samsung 3-core MEX Controller, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES
- 69.85 mm x 100 mm x 6.8 mm
- 53 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 69.85 mm
- 100 mm
- 6.8 mm
- 53 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 410 MBps (write)
- 4KB Random Read
- 94000 IOPS
- 4KB Random Write
- 35000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 0.1 Watt (active) , 0.045 Watt (idle)
- Software Included
- Drivers & Utilities, Samsung Magician Software
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance
- 1500 g @ 0.5ms (non-operating)
