The Samsung M3 Portable External Hard Drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity of 1.5TB. The durable black design stands up to the rigors of daily use.
- Handy portable storage
- Durable black design
- SafetyKey protection for your data
Contents
- M3 Portable External Hard Drive
- USB cable
- Quick Install Guide
- Software preloaded on the drive
- Electronic User Documentation (PDF)
- Windows 7/Vista/XP, Mac OS X 10.4.8 or later
- SuperSpeed USB 3.0 (Max): 4.8Gb/s
- Temperature (operating): 5° to 40°C (41° to 104°F)
- Temperature (nonoperating): -20° to 65°C (-4° to 149°F)
- Weight (Max): 169g (1.5TB)
- Height (Max): 17.5mm max
- Width: 82mm
- Length: 112mm
- 3-year limited warranty
Software
- AutoBackup personal backup solution
- Secure Manager for worry-free data security
- SecretZoneTM can encrypt data on the device
- Samsung M3 Portable STSHX-M151TCB - hard drive - 1.5 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1.5 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Samsung Auto Backup, SafetyKey, SecretZone, Secure Drive
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8.2 cm x 11.2 cm x 1.75 cm
- 169 g
- 3-year warranty
- Capacity
- 1.5 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 8.2 cm
- 11.2 cm
- 1.75 cm
- 169 g
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 40 °C
