The Ricoh SP C252SF color laser MFP offers standard wireless printing and mobile printing capabilities so you can access information where you need it, when you need it. Need to share documents quickly with coworkers and customers? The SP C252SF offers print/scan/copy/fax functionality plus cost-free document distribution capabilities with scan-to-email/FTP/folder and more. Tight on space? The SP C252SF is small enough to fit in cramped spaces, making it convenient for smaller offices. You can even include it as part of a Ricoh managed document services (MDS) strategy and measure how much time and money the SP C252DN can save for your organization.
- Ricoh SP C252SF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 65000 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 90 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 750 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- Office Machine Features
- Save to USB flash drive, Internet faxing, scan to e-mail, scan to folder, scan to network, Locked Print Technology
- Power
- AC 230 V (50/60Hz)
- 42 cm x 49.3 cm x 46 cm
- 29 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 65000 pages
- Interface
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Preset Enlargements
- 129%, 155%, 200%, 400%
- Preset Reductions
- 50%, 65%, 78%, 93%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Sort, photo mode
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 14 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Transmission Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 20 station(s)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 100 stations
- Automatic redialing, smoothing, answering machine interface, one-touch speed dialling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 90 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 160 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), 140 x 216 mm, JIS B5 (182 x 257 mm), 90 x 148 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 750 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets size: 90 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 160 g/m² , Output tray - 150 sheets - Legal (216 x 356 mm) , ADF - 35 sheets - Legal (216 x 356 mm) , Bypass tray - 1 sheet size: 90 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 160 g/m²
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Printing: up to 21 ppm (Letter A) - B/W , Printing: up to 21 ppm (Letter A) - colour , Printing: up to 12 ppm (Letter A) - B/W duplex , Printing: up to 12 ppm (Letter A) - colour duplex , Copying: up to 20 ipm - B/W , Copying: up to 20 ipm - colour , Copying: up to 12 ipm - B/W duplex , Copying: up to 12 ipm - colour duplex , Scanning: up to 12 ppm - B/W , Scanning: up to 6 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, Apple Mac OS X 10.3 - 10.6, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2
- Software Included
- Drivers & Utilities, Presto! PageManager
- Voltage Required
- 1300 Watt
- Power Consumption Standby
- 2.4 Watt
- Direct Printing Specifications
- PictBridge
- Warm-Up Time
- 30 sec
- First Copy Out Time B/W
- 20 sec
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages
- cUL, UL 60950-1 Second Edition, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- 42 cm
- 49.3 cm
- 46 cm
- 29 kg
