Small, smart and energy-efficient, the SP 311DN is designed to impress. Compact enough to fit unobtrusively on a desk, the B/W A4 laser printer will astound you with their speed and efficiency. The device is easy to operate and simple to maintain. Its energy consumption is very low. And it incorporates a host of environmentally responsible features such as energy saver mode and automatic duplex to lower your carbon footprint. In short, if you're looking for fast, compact, energy-efficient B/W printer, you'll find them in the SP 311DN.
Budget-friendly and highly productive
The long-lasting, high-yield, all-in-one toner cartridge gives you an attractive cost per print. Along with a low hardware price, the SP 311DN is therefore affordable investments for cost-conscious offices. This device is also extremely productive. It only takes 26 seconds to warm up and speed along at a fast 28 pages per minute. Automatic duplex further improves productivity - and saves paper too. -
Simple to connect
With standard USB 2.0 and a built-in Network Interface Card (all models), plus Wi-Fi possibilities, these devices will fit neatly into your existing network. You can send each job to the most appropriate network machine. That way, you get the best value from each of your output systems. Fax quickly and efficiently with PC Fax and Super G3 Fax capabilities. -
Environmentally responsible
Lower your environmental impact with features such as short warm-up time, sleep mode, automatic duplex printing, Energy Saver mode, and low typical electricity consumption. In addition, these devices are ENERGY STAR compliant. This means less CO2 is produced in providing the energy needed to run them. -
Easy to use
Full-front operation is straightforward as all the devices feature just a few buttons. You can also send scans to email, folder or FTP and copy both sides of an ID card onto one side of paper. For all models the standard tray takes up to 250 sheets while the 50-sheet bypass tray can be used as second paper tray.
- Ricoh SP 311DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12.7 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 28 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5E, PCL 6
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet bypass tray
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Microsoft Windows Server 2012
- 37 cm x 38.2 cm x 26.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 600 dpi
- First Print Out Time B/W
- 8 sec
- PCL 5E, PCL 6
- Media Handling
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets weight: 52 g/m² - 162 g/m² , 1 x automatic - 50 sheets weight: 52 g/m² - 162 g/m²
- Max Media Capacity
- 300 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- ISO 140001, ISO 14001, ISO 27001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 890 Watt
- Power Consumption Stand by
- 50 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 37 cm
- 38.2 cm
- 26.2 cm
- 12.7 kg
